Old 08-19-2010, 08:25 PM
edadema edadema is offline
Banned
Default 2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core
Deciding on getting one or the other. My main question is does Pro Tools really take advantage of all available cores and hyper threading?
-If so then 2.4 8 core makes more sense and 200 dollars cheaper.
-If not then 3.33 6 core makes more sense.
Called Apple and was even more confused after.
Old 08-20-2010, 08:39 PM
Banned
Default Re: 2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core
Does anyone know if PT 8.0.4 takes advantage of Hyper Threading?
Old 08-21-2010, 08:02 AM
DetroitT's Avatar
DetroitT DetroitT is offline
From what I understand all single processors have faster and larger non sharing backside cache. For rendering this may be faster. Not having seen these new macs it's a tossup.
The 3.33 has the faster ram but only 4 slots.
Your stats indicate a 2.93 MP so unless this is another machine the change would be minimal for Pro Tools.
However the new video cards are what peak my interest.
Hyper Threading is a good question, not only for Pro Tools but plug-ins as well.
BTW the 3.33 6 core and 2.66 12 core made it to my short list.
For 16 GB ram only the 3.33 was dramatic enough to seek 3rd party rem replacement.
(Toss 3GB Apple and replace to 16GB) . The 12 core 2.66 ram was competitive.
Old 08-21-2010, 08:29 AM
Ted Spencer Ted Spencer is offline
Reminds me of a few small-time producers I've known...
Ted Spencer, NYC
tedspencerrecording.com
Old 08-21-2010, 08:36 AM
studiojimi's Avatar
studiojimi studiojimi is offline
what's 200 bucks when it comes to a major work expenditure?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 08-21-2010, 08:53 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
For an extra $200 I would take the 8 core. The future of computers appears to be more and more cores, so that's what software is going to be written for in the years to come. Something else to look at is number of RAM slots. I believe the 8 core is actually two 4 core CPU's, each with 4 slots of ram. The 4 and 6 core models are a single 4-core or 6 core CPU, with only 4 RAM slots. So for an extra $200 you will have double the RAM capacity.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 08-21-2010, 05:50 PM
Andy R Andy R is offline
Couldn't agree more about the RAM. However, as of today, even Apple hasn't utilized 8 cores (16 hyperthreads) successfully with Logic - they perform only marginally better than 4 core models... which is disturbing. Click
Old 08-21-2010, 08:24 PM
Banned
The 8 core is 200 hundred dollars cheaper
Old 08-21-2010, 08:31 PM
Then it's a no brainer to me. My guess is you aren't going to notice the difference in RAM speed, and RAM amount always trumps RAM speed anyways. There are plenty of other things that become bottlenecks long before RAM.
- John
Old 08-21-2010, 08:32 PM
Banned
Yeah I have a single 2.93 and thought I was good but. I was working in another Studio with a similar set up but they had a 2.26 8 core and it smoked mine. So I didn't want to make that mistake again going for the higher Ghz but less cores.
I mix a lot of Pop and when you put AT Evo on 40 tracks you need more and more power. My HD2 maxes out real quick. So I start converting the Plugs to RTAS
I read all these mixed things like the Plug Ins only use one core. So I loaded up my Activity Monitor to see and it shows Pro Tools but not individual Plugins. Is ther another way to test core use by plug ins?
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann Pro Tools TDM Systems (Mac) 9 02-21-2020 10:39 AM
HDX-2 on (slightly revised) 12-core 2 x 2.4GHz 6-core Intel? / RTAS in PT10HD MixerGuy Pro Tools HDX & HD Native Systems (Mac) 10 06-18-2012 07:10 AM
Mac Pro 2010 2.8 GHz Quad Core vs. 2008 2.8 GHz 8-Core audiosf macOS 3 04-07-2011 02:27 PM
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann macOS 4 02-18-2011 07:08 PM
Mac Pro 8 core 2006 vs Mac Pro 8 core 2010 Dusty Angel macOS 7 01-05-2011 08:11 AM
