Old 11-30-2010, 08:28 AM
bfx bfx is offline
Question Mbox "3" on a dated Macbook?
Hi guys and gals
Thinking of buying a new Mbox (3rd gen) or Mbox Pro for an upcoming project. Just recording 2 to 4 channels max using the built-in Mic preamps. Macbook is around 4 years old, has version number 2.1, 2.16 GHz Core2Duo, 1 GB RAM, 667 MHz bus, OS X 10.5.8. This setup must run reeeeally stable cause the machine will be on its own once the recording got started, DAE errors or else are not an option...
Will this work? Any differences in performance regarding the FW / USB? Opinions, experiences? I don't seem to be able to find a Mac hardware compatibility grid at the AVID support site – is there any around?
Thanks in advance!
.bfx
EDIT: Oh yeah, will run 8.0.4, not going 9 so far...
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
Old 11-30-2010, 09:54 AM
DigiTechSupt's Avatar
Default Re: Mbox "3" on a dated Macbook?
It should work fine (it does on my Macbook, which is a 2.0ghz model) - I would STRONGLY recommend maxing out the RAM, though!
Avid Audio Tech Support
Support FAQ
Old 11-30-2010, 10:47 AM
sunburst79 sunburst79 is offline
Originally Posted by bfx View Post
Hi guys and gals
Thanks in advance!
.bfx
Agreed with Digi about maxing out the RAM. It should have 2 GB minimum. Also if your just tracking and latency is not an issue then maxing out the buffer is going to give the machine a little more headroom.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-01-2010, 12:53 AM
bfx bfx is offline
Ok, thanks a lot to both of you!
Was wondering already about maxing out the RAM. Just was not sure if RAM would be an issue with recording only up to 4 channels at once. Well... apparently it is – but I guess shared video memory has something to do with it, right? Well, anyway, just curious.
Thanks again
Old 12-01-2010, 01:02 AM
Dism Dism is offline
Thanks again
Just overall performance, really. Any computer shows a significant performance increase by doubling or tripling the RAM.
While 2GB vs 1GB doesn't seem like much these days... on a computer that old, it represents a pretty massive performance difference.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro luckydjacks FireWire & USB Audio Interfaces (Win) 129 06-20-2014 03:25 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"upgrade" to dated version of Pro Tools LE Jasari149 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-14-2010 11:46 AM
New 27" imac / "original" mbox - need some clear advice.please help !! santococo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-21-2010 10:30 AM
