Processing the mix
Any one know if you can process the whole mix? Take everything out of 1&2 and say run it through a BBE then bring it back into PT. I know I could take the output from the BBE and mixdown to an external deck, just curious if it can be done within PT to bouce BTD.
Re: Processing the mix
Yes. Set-up an insert in the I/O preferences for your outboard gear. The caveat is that you must use the same numbered inputs & outputs for it to work (e.g. outs 5&6 -> external gear -> ins 5&6). You can then select this insert where you would select your plugins (the top of the channel strip).
Steve Always err on the side of perfection. |
If you must run your mix through the BBE(which I highly recommend against) I would recommend going out of PT to an external recorder, rather than going through the coversion process twice in PT, with it's not so great converters.
Hope this is helpful. |
m/s processing | ballerina | Tips & Tricks | 12 | 09-20-2007 09:40 AM |
m/s processing | ballerina | Tips & Tricks | 0 | 08-22-2007 02:50 AM |
What's doing the processing? | idris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-21-2006 06:47 AM |
OK, here's one. DVD pre-processing... | Stuart P. | Post - Surround - Video | 5 | 08-25-2005 06:20 PM |
Processing FX | singerpainter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-29-2004 09:12 AM |
