Articulation with drum tracks in midi editor
How do I change the articulation.
I use the crash on drums it doesn't do full crash but the stick hits the center of the crash How do I tell that note to use the edge crash? not just the Crash right click to what? velocity has anything to do with it? cant figure it out HELP! Did protool 11 fix this issue? using bdf2
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram |
Re: Articulation with drum tracks in midi editor
That is going to have to do with BFD not pro tools.
Most likely its another midi note which triggers the different part of the cymbal. Best to read up on BFD itself. and the kits. I usually just click on the notes with either a midi keyboard in the notes few and find the one I want then you can move all the ones that trigger the sound you don't want to the sound you do. I don't use BFD but I can't imagine it being much different than Slate or Strike... If you are using a internal BFD midi pattern playing back the sequence then you will need to find out how to export that midi and get it onto a midi track in pro tools for adjusting individual midi notes. I'm sure that will covered in a youtube video tutorial or in the BFD manual. In my experience different sounds are triggered by different notes. Like Snare, Snare Rim, and then velocity controls how hard it was hit also like Ride Bell, Ride outter edge... In all the drum Instruments I have used all different articulations (but not harder softer hits) are done via a different but usually nearby keyboard note.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
PT8: Copying notes between tracks in Midi Editor? | dennismil | Pro Tools M-Powered (Win) | 5 | 09-20-2010 11:59 AM |
BFD2 Grooves to PT8 Midi Tracks for Midi Editor? | Reesho | Virtual Instruments | 2 | 01-06-2010 09:27 AM |
deleted MIDI tracks in score editor | michaelm | MIDI | 0 | 11-21-2009 11:45 PM |
Using Pro Tools Midi Editor for BFD2 drum mapping | Qrackaduck | Virtual Instruments | 4 | 10-15-2009 08:53 AM |
Any simple Midi Drum editor for PT7 available? | mrsusan | Tips & Tricks | 1 | 11-25-2006 08:03 AM |
