Old 05-20-2019, 01:04 AM
tnipe tnipe is offline
Default Best way to increase tempo of percussion 1 bpm?
I've gotten some nicely recorded tracks from a percussionist. Now I find myself wanting to increase the tempo of the whole song by 1 bpm. How would you go about it? Can elastic audio do this with no artefacts? If the audio quality of the recording is affected by it, I wont do it probably.
Thanks for your input!
Old 05-20-2019, 04:34 AM
amagras amagras is offline
Default Re: Best way to increase tempo of percussion 1 bpm?
Elastic Audio will do it just fine, only make sure to select the proper algorithm for each track.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-20-2019, 05:30 AM
Sardi Sardi is offline
It will, but it won’t be artefact free. It can never be. Wether it’s noticeable is another story.
As you suggested, I would definitely do it and start with the Percussive algorithm. The fact that you’re increasing the tempo and by such a small amount is in your favour. More than likely, you won’t notice it.
Old 05-20-2019, 05:33 AM
Right , 1 bpm won't be a problem, it will be pretty much the same as using EA for quantization and usually going up has less artifacts than going...down
amagrasmusic.com
Old 05-20-2019, 07:05 AM
Thanks guys, I'll give it a try.
Old 05-28-2019, 06:09 AM
Thiemesen Thiemesen is offline
Right , 1 bpm won't be a problem, it will be pretty much the same as using these advanced mig welders and EA for quantization and usually going up has less artifacts than going...down
What's the value that you may start running into problems at btw?
Old 05-28-2019, 08:01 AM
Depends on the resolution of the session, the content of the track, your luck... You have to experiment and listen in isolation
amagrasmusic.com
Old 05-29-2019, 09:20 AM
DonaldM's Avatar
DonaldM DonaldM is offline
So, if elastic audio creates an artifact, and no one can hear it, does the artifact exist? (A variation of "if a tree falls in a forest...)
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 05-29-2019, 07:24 PM
albee1952 albee1952 is online now
Or, if a man says something and no women are around, is he still wrong?
I agree that EA SHOULD work.....
Steps:
1-Place all audio tracks in TICKS mode.
2-Enable EA on each track, using the appropriate version for each track(Rhythmic for drums/percussion, Monophonic for Bass and vocals, Polyphonic for guitars and keyboards(not midi stuff), etc.
3-Change the tempo to your desired and watch the tracks(EDIT window) and they SHOULD visually change to reflect the new tempo(midi and Instrument tracks are in TICKS mode by default, so those should change tempo without and extra work.
4-If it DOES sound bad(due to EA artifacts, you can always close the session WITHOUT saving(reopen and try something else).
5-Get the demo of Serato Pitch 'n Time Pro and use it in AUDIOSUITE mode and render audio to the desired BPM(Serato PnT is expensive to buy, but its one of the absolute best options for tempo and pitch change with the least artifacts
why does my tempo increase when i bounce to disk? Abel0470 Pro Tools 9 6 07-04-2011 04:59 PM
Gradually Increase Tempo of a Phrase goat1927 Pro Tools M-Powered (Mac) 0 02-17-2010 10:39 AM
Increase Tempo gooner Tips & Tricks 4 05-12-2007 12:33 AM
Increase Tempo of Recorded Song emelare 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-13-2005 01:34 PM
Need to gradually increase TEMPO metrov General Discussion 6 03-26-2005 07:02 AM
