Old 03-21-2019, 03:30 AM
Logichead Logichead is offline
Default Is HDX Firmware Backwards Compatible?
I'm going to be working on someone else's system so I am bringing a bootable drive. They are on ML and PT 10, I am on Sierra and Ultimate. I suspect I will need to update the firmware of the HDX card. How will their ML / PT10 system work with updated HDX firmware?
Thanks. Best...H
Old 03-21-2019, 03:41 PM
Default Re: Is HDX Firmware Backwards Compatible?
Anyone have any idea about this?
Old 03-21-2019, 06:21 PM
TOM@METRO's Avatar
I'm reasonably sure that if a firmware update is required, and if it does not allow older releases to run, there will be a way to reverse it. Backward compatibility is the Pro Tools way.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-21-2019, 09:41 PM
Thanks Tom. I'm working at a new client's studio, it would really suck to update the HDX card only to have it not work with their system.
Old 03-25-2019, 06:42 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Best to square it up with the top tech at the clients studio.
Old 03-25-2019, 05:57 PM
innesireinar innesireinar is offline
I got a new HDX card in late 2016 and it asked me to update the firmware. I did it and haven't had any issue. At that time I ran PT10 on maverick and PT11 on yosemity.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 03-30-2019, 08:13 AM
Fidelis Fidelis is offline
I think it is backwards compatible. Sometime ago a producer came to my studio and wanted to run PT 10. I was running PT 11 on a different Mac OS. I just plugged his hard drive, booted and it worked.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 04-01-2019, 03:36 PM
Arrow Re: Is HDX Firmware Backwards Compatible?
Thanks. Best...H
If they want any assurance that this will work, they need to be running at least v10.3.6. That was as far back as Avid tested for backwards compatibility with HDX firmware revisions.
Old 04-10-2019, 09:23 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I boot in Pt10 / Yosemite as well as Sierra/2018.12 without any issues.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 04-10-2019, 09:54 PM
YYR123's Avatar
YYR123 YYR123 is offline
This is actually a really good question, since new firmware will be coming out soon with the new voices release (assuming)
Will this new firmware work as good or better than current versions?
Will Avid go back again to V10.3.6 as the baseline?
Daniel
D-Command Firmware update backwards compatible? inky macOS 4 09-18-2014 01:48 PM
Are Firmware Updates backwards Compatible? teacherman Tips & Tricks 1 05-03-2010 09:49 AM
Is firmware backwards compatible? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-26-2007 08:52 AM
Backwards compatible nickster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-25-2006 09:09 AM
SCC BACKWARDS COMPATIBLE nathan jenkins Digidesign Hardware & Software 0 08-07-2001 05:19 PM
