Old 08-26-2011, 10:37 AM
bnjmn84 bnjmn84 is offline
Default PT9: Required software extensions are missing
Hello,
After buying EWQL PLAY, Pro Tools won't startup. It gives me the message: "Required software extensions are missing." I never had this before and I've tried almost everything to solve it (reinstalling PT, reinstalling PLAY, updating iLok drivers).
The only thing working is when I run either the update for PLAY or iLok. The problem is: I have to do this EVERY TIME I boot my Mac!
Can anyone help me out? I'm runnig out of options...
Thanks a lot!
Greetings, Benjamin.
Old 08-26-2011, 10:54 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: PT9: Required software extensions are missing
Have you tried reinstalling PT and trashing prefs?
What other troubleshooting have you done?
http://duc.avid.com/showthread.php?t=54888
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 08-26-2011, 01:57 PM
Thanks for the reply.
Here's what I've tried so far:
> Uninstalling PT (including deleting all pref folders)
> Install latest iLok drivers
> Install latest PLAY update from East West
> Upgrading PT8 to PT9
> Install latest PT9 update 9.0.5
Hope anyone has a solution.
Benjamin.
Old 08-26-2011, 02:01 PM
Dism Dism is offline
What version of OSX on what Mac?
I also would not use 9.0.5 for the time being.... but that's just me.
I have PT9.0.0 and Play 3.0.21 running on OSX 10.6.5 just swimmingly.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-27-2011, 08:14 AM
Delete Pro Tools preferences.
-Go to Users > “your user name” > Library > Preferences
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
-Empty trash, then restart the computer.
You can also use the Pro Tools Preference and Database Helper to trash preferences and databases automatically, as well as providing a few other useful tools. (This application is provided by a 3rd party and is not tested or supported by Digidesign)
Repair Permissions
-Quit Pro Tools and launch Apple's "Disk Utility" application, located in:
MacHD>Applications & Utilities.
-Select your boot drive (the whole drive, not the volume underneath the drive)
-Go to the 'First Aid' tab and select "Repair Disk Permissions"
Apple recommends doing this any time you install new software, update your OS or install any software.
See other suggestions here: http://duc.avid.com/showthread.php?t=54888
Park
Old 08-28-2011, 08:51 AM
Thanks Dism. I'll make sure to use the 9.0 of PT for this time being.
Park: thanks for support!! I don't even remember what it is that stopped PT9 from opening, but after following your steps, I'm golden!
Benjamin.
Required software extensions are missing... SPC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-25-2011 02:31 PM
Required software extensions are missing??? bootyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-26-2010 06:13 PM
Required software extensions are missing... rinky Pro Tools TDM Systems (Mac) 1 12-02-2008 09:51 AM
REQUIRED SOFTWARE EXTENSIONS ARE MISSING? Triple Threat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-21-2008 03:38 PM
"required software extensions are missing" frankreverbo Pro Tools TDM Systems (Mac) 8 01-24-2008 10:51 AM
