Old 03-07-2016, 04:13 PM
Inglesworth Inglesworth is offline
Default C/R Monitor calibration setting
Is there a way for the C/R Monitor display to show a calibrated SPL display? It is pretty common for Film/TV mixers to have the room calibrated to a specific dB for monitoring (79, 83, 85, etc.), but the display on the knob only seems to show full scale monitoring (the number is anywhere between -95.50 and +31.00).
On the ICONs, this was a pretty simple change. You hold down the encoder for 3 seconds and then you turn it to select the display you want. I can not for the life of me figure out how to change this on the S6.
Any ideas?
Old 03-07-2016, 06:11 PM
EddieJones's Avatar
Default Re: C/R Monitor calibration setting
This is not implemented on S6 yet but there is a EUCON command called fixed level so it will be eventually. But this would only be reliable for 1 setting not a few as the difference in db would vary from studio to studio depending on room size, speaker sensitivity etc. So whilst you could line your room up to say 85, turning the volume down to 79 may or may not actually be 79 in your room.
Old 05-19-2016, 08:49 AM
innenhofstudios innenhofstudios is offline
do i understand this correct... there is no "reference level" knob/setting ? how about implementing this ?
Old 05-19-2016, 09:11 PM
EddieJones's Avatar
Its on the list to do but as there is an easy workaround other things are taking priority at the moment.
Old 06-01-2016, 11:31 AM
StonehengeX StonehengeX is offline
I can't tell you how frustrating this is in post. Whether a work around exists or not this should be a top priority.
Old 09-08-2018, 06:05 PM
Just ran into this today so googled it - hard to believe it's not possible, but I guess...not yet?? Still??
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-08-2018, 08:58 PM
its2loud its2loud is offline
Was also posted and asked for here.
http://duc.avid.com/showthread.php?t=399511
100% agree its a much needed feature.
Monitor Calibration Question. philip888 Tips & Tricks 2 02-24-2014 03:28 PM
Monitor Calibration daustin777 General Discussion 1 01-23-2005 08:53 AM
whats the calibration level setting in preferences Seeee Pro Tools TDM Systems (Mac) 2 11-16-2004 02:42 PM
Monitor Gain/Calibration Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-18-2002 09:55 PM
Monitor Calibration KamaSutra77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-09-2001 07:12 PM
