Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 04-14-2018, 01:52 PM
seanmccoy seanmccoy is offline
Default 192 Crackling on two channels
Hey all. Using a 192 slaved to an Omni. Recently started getting consistent crackling from input channels 7 & 8 on the 192. Sounds much like a clock problem, but the setup is correct and channels 1-6 are clean. I've never had the box open, and I'm wondering if there separate internal cards for each channel or pair of channels? If so, it could be just a seating issue, or a simple replacement. Hoping to avoid having to ship the whole box out. Any advice from experienced users welcome.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2018.7, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Quad; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.3, Apogee Rosetta 800, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Sierra, MOTU LP32, Pro Tools 2018.3
Old 04-14-2018, 08:25 PM
Default Re: 192 Crackling on two channels
Not sure I would ship the box anywhere, but there are some things worth checking(assuming you have 2 BNC cables completing Loop Sync connections and the 192 has a Digital IO card in slot 3(IIRC, this is required). I would pull the unit out of the rack, pop the top panel and find the multi-pin connector on the Input card. Unplug it and do a thorough inspection of pins and sockets. Maybe hit it with some good contact cleaner and re-connect and test. If that makes no difference, instead of shipping the unit, I would just shop for a deal on another analog input card and replace the fouled card. If that fixes it, great. If that DOES'NT fix it, then you know its not the card, BUT, in that case, stick the old card in slot 4 and see if it works there(which might be worth a try anyway)
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 04-15-2018, 08:23 AM
Excellent, thanks, I'll give it a look. I think I still have an ancient can of Cramolin sitting around here somewhere...
Old 09-24-2018, 03:10 PM
danyull danyull is offline
Any luck fixing this? I have the same issue.
Old 09-24-2018, 03:46 PM
Sorry, I confess I never followed up on it. It's so rare that I need more than the four channels on my Omni that I haven't gotten around to it. I do use the 192 as an input for my talkback channel, but I just moved that over to 5 and moved on.
Old 11-04-2018, 04:09 PM
jyt jyt is offline
Hi, I have pretty much the same problem here, just bought a 192 unit of ebay with 8 a/d and 8 d/s and digital in/out, have test all the a/d and get crackling (like statics noise) on channel 1 and 2, the other 6 are perfect, i will try to dismantle the whole thing and give it a clean up, perhaps that will do the trick and i will let you know what i found. I will also try to card on slot 4 which is the slot below the digital in/out slot, right?
Old 11-08-2018, 07:08 PM
Well, my problem seems to be spreading. Channels 7 & 8 are extremely crackly, and now channels 5 & 6 are starting to crackle. Kinda like the unit has gangrene. Channels 1-4 are still clean, but I'm thinking now I better get this dealt with before the whole thing takes a dive. Weird stuff.
Old 11-17-2018, 03:08 PM
I spoke with Thermal Relief about repairing the 192, and they said they could do it but that the cost would be more than just buying another used unit. They also said replacing the malfunctioning analog input cards is such a cinch that I should do it myself, and that the cards are readily available on Ebay. I'm game for that, but I'm finding zero cards available on Ebay or anywhere else. Anybody aware of a source for old Digidesign components?
HTML code is On
Live Recording Mackie 16 channels into 16 PT channels 67Thunderbird Pro Tools 10 22 10-26-2014 02:10 AM
Not enough ASIO output channels available.at least 2 channels are needed. kudca Getting Started 1 05-26-2013 05:05 PM
Crackling DB-33 Drunken Mixer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-16-2009 06:27 PM
Crackling Pop - Please help tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-13-2008 11:03 AM
why crackling? mariushfm Digidesign Hardware & Software 4 04-10-2003 02:33 PM
