Old 05-10-2007, 11:26 PM
Curve Dominant Curve Dominant is offline
Default 10-BaseT Ethernet Hub - Which Most Highly Recommended??
Yes, I did a search, which came up nada, and the D-Control manual states it is not included.
So, what are all you "power-users" using for ethernet hubs, for connecting all those ICON modules?
And, are there any esoteric issues regarding the ethernet domain, which are not covered in the manual?
Thanks in advance!
-Eric Vincent @ Studio Curve Dominant
Eric Vincent
http://www.curvedominant.com
Philadelphia USA
[email protected]
Old 05-11-2007, 04:36 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: 10-BaseT Ethernet Hub - Which Most Highly Recommended??
afaik it doesn't matter. 10 base T is the protocol so fast enough. I doubt a setup will relly benefit from 100 or giga hubs although ours is hooked up to a D link giga switch.
I would recommend a switch over a hub however .... although most of the usints I see these days are switches really. And of course if you have other computers on the network then get a gigabit router. Transfer between computers / network drives benefit from the routers' speed. But the Icon units are more then happy with 10 base T
Chris Lambrechts
Applications Specialist- Live Sound
Old 05-11-2007, 11:08 AM
Thanks Chris.
Is there a brand you would recommend?
Eric Vincent
Philadelphia USA
[email protected]
Old 05-13-2007, 08:25 AM
ishur ishur is offline
FWIW I just use the same, inexpensive four port Linksys hub I already had in the studio to connect my two Macs (one is for music, one is not) to the internet. Just plugged both ethernet cables from the D-Command into the hub right alongside the two macs and never thought about it again.
2.1.3 patch - highly recommended to install it cmarkle_aspera Aspera DigiDelivery 2 07-29-2008 07:00 PM
Highly disturbing groovilator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-04-2005 11:27 PM
Highly annoying 002 pops tclash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-31-2005 03:21 PM
advice on this mix will be highly apprec. tantejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-09-2004 11:51 AM
XP Upraders... I HIGHLY recommend... Phil O'Keefe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-24-2002 01:20 PM
