Old 08-18-2019, 02:46 PM
Led Led is offline
Default Re: Windows 10 1903
Originally Posted by BScout View Post
Why is that happening to you? No issue here. Run as admin is just run as admin -- doesn't affect how the program interacts for me.
We might be talking about different things..I mean when you right click on the PT desktop shortcut and open the properties tab, then check the box that says 'run as administrator'. This fixed the random cpu spiking that happened with some earlier builds, but stopped you being able to drag and drop. It's different to running the program normally but logged on as an administrator. I don't run that way, but it might be worth seeing if it stops the spiking for OP..
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 08-18-2019, 03:36 PM
BScout BScout is offline
Yes, I'm talking as running from an administrator account and not the per application compatibility switch to "run as admin."
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-19-2019, 09:48 PM
ibbod0 ibbod0 is offline
Update: Still working fine after all. Not even running as admin.
I skipped from 1709 to 1903 using the ISO, not Windows Update, so maybe there was a difference there. It was not performing well until I installed Pro Tools 2019.6 over the top of the existing 2019.5 installation. I can't say if 2019.6 works better or if reinstalling 2019.5 would have done the trick just as well. I guess it's always worth a try reinstalling drivers/software just to be sure nothing got broken.
Just to conclude my original query: As others have confirmed, Windows 10 1903 itself doesn't have any issues. I actually get better performance now.
Gigabyte Z97X-UD7 TH / Intel Core i7-4790K @ 4.00GHz / G.SKILL Ripjaws X Series 16GB / Samsung 850 Pro SSD / WD Blue 1TB HDDs / Audient iD14 / running Pro Tools 2019.5 on Windows 10 1709
Old 08-20-2019, 11:17 PM
The 1903 builds before the July update had serious DPC latency issues. Some system drivers-kernals would hang on some processes and cpu spikes would go crazy. The July update resolved those issues.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
2019.5 on Windows 1903 gnjlee Pro Tools 2019 3 05-11-2019 05:47 PM
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 2 05-07-2018 11:57 AM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire and USB Audio Interfaces (Win) 6 12-25-2015 03:40 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
