Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 07-14-2019, 11:17 AM
reichman's Avatar
reichman reichman is offline
Default Move Sel & Edit command logic
Ever since day one with the Dock, I've found the Move Sel function with the wheel tremendously useful. But there's always been some inconsistency about whether the moving selection was just a location, or an actual selection.
For example, go into Move Sel with just the cursor, wheel over a clip and hit 'b' for separate clip. It usually works the first time, but about 30% of the time it doesn't, depending on what function you completed before. The same goes for 'c' for copy. Make a selection in Move Sel (using Mark In/Mark Out) move that selection, hit 'c,' there's a good chance that the first time you hit 'c' nothing went into the clipboard. I find myself hitting these commands twice, just to make sure they worked.
Eddie, maybe this is because Move Sel is intended for location and not editing, but I'm having trouble figuring out the logic. EuControl 19.5.1, PT 2019.6, macOS 10.12.6 (but this behavior has been present since I purchased a Dock years ago).
TIA for thoughts.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Move edit window down? dg27 Pro Tools 12 0 07-18-2018 02:56 PM
Won't let me edit or move anything? Shicks1 Pro Tools 12 3 12-12-2016 07:01 AM
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 03:20 PM
Markers Move With Edit... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-17-2006 02:57 AM
Move Edit Sel Up/Down Siegfried Meier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-15-2003 12:27 AM
