Old 04-28-2016, 09:49 PM
blizzard blizzard is offline
Default Frozen tracks = No tempo ruler editing
I have just upgraded to 12.4 on my PC, and changed my composing template. I was previously using VEPRO to host all VI's, but now I'm freezing all VI's hosted within Pro Tools via the Track Freeze feature.
This is the error I get:
The tempo ruler cannot be edited because the session contains one or more frozen tracks. Unfreeze all tracks before editing the tempo.
A workflow killer I just came across during my first session was that I can't edit the tempo of the session if I have any frozen tracks. When you're using the Track Freeze feature to host a huge amount of VI's or plug-ins within Pro Tools, this can take a while. It also requires me to remember (or keep a list of) every track I unfreeze while composing with the template. The whole purpose of a template is to have everything ready at your fingertips and speed up the process. Not slow it down.
Anyways, just whining over here. Anyone have a similar issue and have found a decent workaround? Go back to using VEPRO?
Cheers,
Andrew
DAW - Asus P9X79 / 32GB / i7-4820K / WIN7 PRO / VEPRO 5
PT 11.3.0 / Blacklion 003R / Microclock
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.4
Old 04-28-2016, 11:11 PM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Frozen tracks = No tempo ruler editing
It seems you need to commit tracks instead of freeze them if you want to edit the tempo ruler. Or you make a "freeze/unfreeze" group of selected tracks you need to unfreeze all at once, edit something and re-freeze them again.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-29-2016, 03:52 AM
midnightrambler midnightrambler is offline
At least that one gives an error. Try duplicating or "consolidate all VCA automation" or any one of a thousand other commands and you'll get nada - no indication whether the command has worked or not. This has caught me out enough times to make sure I never use freeze for anything, other than as a strictly temporary measure.
Old 04-29-2016, 09:04 AM
john1192 john1192 is offline
since Slate SSD4 does NOT hold it's settings when using Make InActive / Make Active .. freezing does not work yet for SSD4 ... so i cannot Freeze, unfreeze and make changes .. i hope this is fixed soon ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 04-29-2016, 09:34 AM
To john1192, this is a different issue(belonged in its own thread), but your solution would be to save the settings as a preset in the plugin.
To blizzard, indeed, using Commit is the proper way to deal with this.
Old 04-29-2016, 11:33 AM
daeron80 daeron80 is offline
That's expected behavior, though. There are only two logically possible alternative designs. 1) Allow tempo track editing to throw frozen tracks out of sync following the tempo change. 2) Make all frozen audio automatically be Elastic, which would consume vastly more processing power. IMHO, Avid chose the best option.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
Tempo Ruler Bug Dizzi45Z Pro Tools 12 0 03-24-2016 02:55 PM
Tempo ruler not affecting all tracks sssonic Pro Tools 9 4 12-04-2011 10:44 AM
Calculate tempo does not match tempo ruler sssonic Pro Tools 9 1 11-07-2011 10:34 AM
Problems with Tempo Ruler in PT8 Ottosmu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-24-2009 08:29 AM
Metronome and Tempo Ruler on transport bar nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2006 05:58 AM
