Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 01-11-2013, 12:54 PM
Paudman Paudman is offline
Default USB M-Audio Fast Track is there.. then it's not.
Hi folks. I'm running Mac OSX 10.7.5 with the updated version 8.0.3 of Pro-Tools Essentials.
The problem is that the input device, my USB FastTrack (front knobs) won't work. When plugged in the green front led illuminates for about three seconds, then goes out again. The blue LED stays on all the time.
When I open OSX Preferences it says there is no device connected; then suddenly changes to "a device is connected and settings will be applied immediately" and a device is registered as a M-Audio Fast Track, so it's the correct device, however the green light on the box stays off and it doesn't register with Pro-tools Essentials. If I reopen Preferences I get the same dialogue again - no device, then a device, but at no time does it light up green and allow me to record.
I've uninstalled the drivers and tried the latest version, 1.8.2 and firmware 1.01. but it's still the same. I unplug the USB, Pro-tools quits saying it can no longer connect to the device.
SO: the device is there... but it won't play with Pro-Tools Essentials.
Any tips?
Old 02-04-2013, 05:55 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: USB M-Audio Fast Track is there.. then it's not.
Any tips?
Obviouis things to check..
new USB cable
Different USB connection on the computer
Connect directly to the computer (Not through a USB hub)
Anything else on the USB bus that could be drawing too much power away from the interface.
The interface itself doesn't have a faulty USB socket?
If its a new interface. take it back as faulty!
Could try trashing the AMS prefs and re-installing the fast track drivers. also uninstall the fast track drivers before re-installing if there's an uninstaller available.
details for deleting AMS prefs and other troubleshooting stuff...
http://duc.avid.com/showthread.php?t=54888
Chris
Producer, Engineer,
www.ukmastering.com
Upgrade from M-Audio Fast Track Pro audio interface. lambono General Discussion 7 04-08-2013 10:05 AM
M-Audio Fast Track / M-Audio Venom in Pro Tools 10 leinad MIDI 1 09-16-2012 09:13 PM
M-Audio Fast Track Pro w/ LE 8.0.1 digimog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-23-2010 05:18 PM
m-audio Fast Track Pro shawn wytch Pro Tools M-Powered (Win) 1 01-05-2009 10:23 AM
m audio fast track pro question neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-18-2006 03:25 PM
