Old 04-09-2008, 02:01 PM
Jose Alva Jose Alva is offline
Default Is PPro Tools LE compatible with Apogee Duet?
Is Pro Tools LE compatible with Apogee Duet?
I'm tryin' to set up a home studio. I'll appreciate any suggestions
(I have 2 Macs: 1.25 GHz dual G4 with both OsX and OS9 and 2.3 GHz G5 with OSX 10.4.11)
Thanx in advance
Old 04-09-2008, 02:18 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Is PPro Tools LE compatible with Apogee Duet?
Not in any way that you'd find useful.
Old 04-09-2008, 03:57 PM
Mr. Anderson Mr. Anderson is offline
No.
Old 08-01-2008, 12:57 PM
audiocase audiocase is offline
Default
hi Jose,
Late reply here...
as for the suggestions:
If you really want to use pro-tools 99% of the time, then your best bet is to perform all your live recordings through the duet into garageband/logic then open them in PT using a digi interface to edit , mix e.t.c
for example mbox mini for pro-tools( editing, mixing) and
Apogee duet for GB/Logic(only recording) ...but then you already know that.
Too bad the duet has no digital I/O
Be ready to capture the magic... even in your sleep.
Old 08-25-2008, 01:01 PM
Suriel Zayas Suriel Zayas is offline
new to this, but here it goes. i guess i can't use pro tools le (standalone, without interface) to edit work? then my question is, what protools version can i use to edit without an interface, just using the computers speakers? thanks.
Old 08-25-2008, 01:11 PM
joe.cavers joe.cavers is offline
The answer is none, Pro Tools LE does not run without hardware attached. The cheapest way to run PT LE is with the Mbox Micro, which only has a headphone output. You can run PT LE with this but it has no ins/outs so you can't record any audio. If all you're doing is mixing audio and playing with midi however, this is fine.
Hope this helps
Joe
Old 08-25-2008, 02:35 PM
stoneinapond stoneinapond is offline
Originally Posted by audiocase View Post
...If you really want to use pro-tools 99% of the time, then your best bet is to perform all your live recordings through the duet into garageband/logic then open them in PT using a digi interface to edit , mix e.t.c ...
Audiocase,
Have you done this yourself? The reason I ask is that I have to do a project where all the source material is in GarageBand. I've briefly looked through the manual, but the only way I can see of doing this is to export each track into iTunes and then take those files and import them into PT.
That seems like a lot of unnecessary work.
Any ideas?
Old 08-25-2008, 02:55 PM
Originally Posted by joe.cavers View Post
Hope this helps
Joe
thank you joe.
Old 08-25-2008, 06:16 PM
Originally Posted by stoneinapond View Post
Audiocase,
Any ideas?
hi,
You're right. Anything coming from garageband is a lot of work but If you have logic then you're in luck.
Simply open the gb project in logic and then export ( either by OMF/audio tracks and then export the midi if any)
I dont like using GB or logic that much, but in logic you could export the midi tracks as well as the audio and open them up in PT. Be sure to name all your tracks before you midi export them (for softsynths) and/or audio tracks.
Old 08-26-2008, 06:30 AM
Thanks for the reply Audiocase,
I do not have Logic, so I guess its going to have to be the long way home.
Ah well....
Pro tools 10 with Apogee Duet ? Vides7 Pro Tools 10 1 01-02-2012 12:20 PM
Pro Tools and Apogee Duet Rhythm_Writer Pro Tools 9 13 04-15-2011 04:41 PM
Pro Tools 9 and Apogee Duet Rhythm_Writer macOS 1 04-12-2011 12:08 PM
Pro Tools 9 with an Apogee Duet Crow74 Pro Tools 9 24 12-27-2010 04:34 PM
Apogee Duet & Pro Tools 9? bradweeks80 Pro Tools 9 4 12-24-2010 10:47 PM
