Old 02-08-2019, 02:41 AM
Peters86 Peters86 is offline
Default Delay compensation not working when committing??
Hi guys,
I have a big issue here. I need to deliver a mix today and I'm running some drum tracks through my hardware. I use an Apogee converter. I add inserts to the tracks in PT, when monitoring everything sounds fine. However, when committing (online of course), the committed track is delayed! I have ADC activated. The track does not seem to be delayed based on the buffer size, as changing the buffer settings does not affect the amount of difference. The difference is about 5-15 ms.
I'm using PT12.4 native on OSX High Sierra (the last compatible version).
PT seems to know how much delay is caused by the AD/DA conversion as it mentions that in the mix window, but how do I fix this? Any help is much appreciated.
Old 02-08-2019, 08:09 AM
Default Re: Delay compensation not working when committing??
Apologies if I'm not understanding, but you have external analog inserts on the channels? If so, you obviously can't do an offline bounce/commit - needs to be real time.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-08-2019, 12:49 PM
Sardi Sardi is offline
Exactly.
You can’t be committing offline if you’re going through outboard gear.
Old 02-09-2019, 03:31 AM
My bad, sorry. I meant online, in realtime.
I seem to have (partly) figured out what's going on. A few months ago I calculated the roundtrip latency and inserted that value (11.5 ms) in the I/O screen. However, upon remeasuring the latency, it suddenly has changed to 16 ms, which is roughly the difference in alignment I'm noticing. I have no idea what could have caused this as I have not upgraded my system, hardware or anything else. Quite mysterious!
Old 02-14-2019, 12:09 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
I have also noticed that...an apparent instability in maintaining a consistent internal compensation. PT's timing generally is flaky at best. There are times when (usually after intense editing) PT 12.8.1 doesn't even move according to the grid. Although this is different from what you are talking about, I've found that restarting almost always corrects it.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 02-15-2019, 06:57 AM
Thanks, I'll keep that in mind!
Delay Compensation not working Antiphones Pro Tools 12 14 09-05-2017 12:15 PM
Delay compensation not working right on inputs? Luigi2000 Pro Tools 12 10 10-03-2015 01:29 PM
Delay Compensation working in reverse??? Eric Lambert Pro Tools 10 12 02-09-2015 08:15 AM
HD Native Delay Compensation not working! nuancerec Pro Tools HDX & HD Native Systems (Mac) 10 01-24-2011 04:12 AM
Delay Compensation Has Stopped Working voce Pro Tools TDM Systems (Mac) 5 07-08-2009 12:32 PM
