Error -9126 on a working drive
Hi guys,
Thanks for all the knowledge in these forums. I have an issue that I couldn't find specifically. I get the 'Could not complete your request because DAE error -9126 was encountered..' on some sessions but not others. I am working on 15 songs for an album and today I just went thru and changed some plugin settings on one and then copied it over the other 14 and now one just gives me this message while the other open. They are all on the same internal drive that has been working fine and does. This happened the other day and tried opening up a version of the same session from Time Machine and still got the message. I ended up opening a different mix of the session and I imported the settings and used the session for about a week and now it has happened again. One thing I did notice is I have PSP Mix Saturater and sometimes when I open a session it has kind of locked up and the meter is indicating full blast! So I have to deactivate/re activate the track and its fine..... Could this error also be plugin related? Mac Pro 2,1 3GHZ 8 core 10.6.7 8GB Ram PTHD2 8.1.1 in magma chassis Last edited by STL Audio; 10-31-2011 at 07:33 PM. Reason: Typo's |
Re: Error -9126 on a working drive
Has no one had this issue?
Or no suggestions? TK |
sorry no Time Machine allowed using PT, same of disable spotlight, they said clearly in OSX configuration for PT.
i'm shure of this. to back up your sessions use "save copy in " |
DAE Error -9126, but seems I'm set up the right way | Lopan | macOS | 1 | 10-21-2012 10:37 PM |
DAE Error -9126 | Parches | Pro Tools TDM Systems (Mac) | 1 | 02-10-2012 09:56 AM |
DAE Error 9126 using separate Internal Drive | Brightbelt | macOS | 2 | 05-22-2011 03:33 PM |
DAE error -9126 | Pompolius | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2011 12:05 PM |
DAE -9126 on Mac drive but not windows? | CrAkD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-25-2010 09:50 PM |
