Old 03-01-2011, 12:42 PM
hyperballad400 hyperballad400 is offline
Default stereo/mono -- NPR reporter needs your help (again)
hi folks,
the last time i posted here, i got excellent advice, so i'm crossing my fingers for a repeat! :)
i recorded a call on Skype and it created a stereo track, where one side has all this static on it, and the side with my subject sounds perfect (thank god). i want to remove the bad side, and keep the good side.
the only problem is that the "Split into Mono" option under Track is greyed out!
what should i do?
i'm running Pro Tools 7.1 on Windows XP.
thanks very much for any help!
Old 03-01-2011, 12:50 PM
RRRS RRRS is offline
Default
Did you highlight the region first before you tried to split?
Not at my studio but you can always send to a stereo buss and make a new mono audio track and select one side of the buss as your input.
Though, split to mono should work...
Sent from my EVO 4g using Tapatalk...
Gigabyte GA-EX58-UD4P
i7 920 2.66
12 gig OCZ Platinum 1333
Zalman 9900 LED
Readeon HD 4650
6 tb storage
WIN 7 x64 Ult
PT9
002 Console, 11R, Profire 2626, Jamlab
MPT2(wtf?)
HP DV7-3188cl
i5
320g 7200rpm hd X2
Siig xpress 1394
6 gig ram
(disabled g105 and acpi
Old 03-01-2011, 01:15 PM
Default Re: stereo/mono -- NPR reporter needs your help (again)
thanks RRRS - yes, i did highlight the track.
as for the other option you mention...i've never tried such a thing and am not quite sure what you're referring to! would you be able to elaborate?
thanks again!
Old 03-01-2011, 01:27 PM
stonehenge stonehenge is offline
not sure why you can't split into mono if a stereo track is selected.
you could just create a new mono track and drag the good channel from the region bin onto that track.
Old 03-01-2011, 01:40 PM
stonehenge -- thank you! dragging the desired channel from the region window did it. of course it was glaringly simple. :)
thanks again to all the folks who participate in these forums...they are so great.
[IMG] code is Off
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Mono/stereo Stereo mono..... What happen here ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2004 09:28 AM
stereo file to mono and mono too stereo ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2003 07:52 PM
