Old 09-18-2004, 02:50 AM
Erik Braund Erik Braund is offline
Default compressed snare without washy cymbal bleed?
Hi - I am finishing mixing a 5 song rock band right now, double kick / 4 toms.. that kind of thing.
Anyway, i lightly compressed the snare pre-PT, but they want a really really compressed snare sound. I have a light compression on the whole drum submix, but when i focus on fattening up the individual snare track with comp, it sounds great until the release when the hi-hats and other cymbals bleed through and ruin the stereo image I had going.
I've been trying to gate it, but I just can't get this one right.
Any suggestions for this session, or future ones (on avoiding over compressed cymbal bleed but keeping the super-compped snare sound)?
Thanks! Erik B
Clive Davis Dept of Recorded Music
NYU
Old 09-18-2004, 02:30 PM
spigots spigots is offline
Default Re: compressed snare without washy cymbal bleed?
You might want to consider triggering a companion to help with the sound they're looking for.
Back when I was recording bands years ago, I found that having the "final" drum sound about 90-95% there when tracking helped avoid this kind of mix dilemma.
Frank
Old 09-18-2004, 03:27 PM
Naagzh Naagzh is offline
Duplicate the snare track, EQ out the cymbal bleed on the dupe track. Then, compress the heck out of it and blend it back in with the original.
Never tried it, but it could work.
In the future, build a sheild around the snare mic with auralex or cardboard or something.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 09-18-2004, 05:03 PM
Extreme Mixing Extreme Mixing is offline
If you like the compressed snare sound up to the release, then why not copy the snare down to a new fader for the release, and treat it differently than the rest of the track.
As was mentioned above, you may want to trigger a sample to help the snare. The nice thing about that approach is that you can compress it as much as you want without affecting the cymbals.
Steve
Steve Shepherd
Extreme Mixing
Old 09-19-2004, 05:14 AM
audiaudio audiaudio is offline
Use Strip Silence to remove from the snare track everything but the snare. Then compress to taste. If you can't make Strip Silence work perfectly, follow up by editing the track by hand to isolate the snare.
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 09-19-2004, 10:28 AM
You also might try compressing the overheads more. There's probably quite a bit of snare in those tracks, and the compressed cymbals and toms might actually serve the mix.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 09-20-2004, 01:11 AM
thanks for all of your help guys! It was a crappy sounding snare and he played his hats really low. I am printing this thread to take with me to the studio tomorrow!!
Thanks again, Erik B.
NYU
Old 09-22-2004, 04:20 AM
ndlsd ndlsd is offline
There is the simple professional answer to this question. Use a de-esser. The top mixers in the world use this trick all the time. A de- esser on the main snare drum track can have a huge effect controlling hi hat bleed. You can then re-eq back in the high end you want on the snare drum after wards. This is the best solution for a badly bleeding snare mic. You can thank me later.
Old 09-22-2004, 08:19 PM
minister's Avatar
minister minister is offline
another, unrelated, dess trick, is to put one on a squeaky acoustic guitar. works great to minimize string noise..
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
snare mic bleed question. nerhal The Drum Room 17 10-12-2010 03:46 AM
Help!! How to handle snare bleed on drum tracks?? el biciclista Pro Tools TDM Systems (Mac) 19 11-21-2006 11:20 AM
too much hihat bleed on snare track any tips? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-05-2005 03:24 PM
High Hat bleed in snare track qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-13-2004 12:20 AM
Creating a MIDI trigger from an acousitc snare/cymbal? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2002 04:50 PM
