Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 02-18-2024, 03:17 AM
scenaria scenaria is offline
Default Need Hybrid response code for authorization
Can someone from avid support assist?
I opened a case file but it was closed by Avid.
I had to reinstall an updated emix and converted a 264 into a
264D. Hybrid authorization code is needed for the app.
Case number is 04759125
Old 02-18-2024, 04:26 AM
tope d's Avatar
tope d tope d is offline
Default Re: Need Hybrid response code for authorization
Checking on this and will get back to you.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-18-2024, 04:30 AM
tope d's Avatar
I’ve just checked and the support team already sent an email
Might be in your spam or junk folder.
Pasting it below
Hi Steve,
Thank you for contacting AVID.
We regret to inform you that Avid already ended it's support for System 5 on 3/31/2021.
[https://avid.secure.force.com/pkb/ar...nd-of-Support]
You may check about Euphonix System 5 Hybrid Installation & Configiration from the link below:
http://apps.avid.com/installguides/I...E%20PC254H.pdf
-Tope
www.topedomingo.com
Old 02-20-2024, 10:38 AM
EddieJones's Avatar
Is this Steve Yost?
Old 02-20-2024, 10:40 AM
EddieJones's Avatar
Pasting it below
Hi Steve,
Tope, we still have the server running to generate these codes, so you can send them to me and I'll deal with them. Thanks Eddie
No response from Avid (ASC code not working) Andreilazo Licensing & Accounts 1 10-16-2020 06:06 AM
Purchased support code - no response. help! oxygenstudios Licensing & Accounts 1 01-22-2016 04:45 PM
Hybrid slow CC response!! Ludw:g Virtual Instruments 1 07-31-2007 07:23 PM
Confused about authorization challenge-response Robert U Tips & Tricks 3 09-25-2000 04:57 PM
