Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 02-05-2022, 01:31 AM
MatrixDigital NZ MatrixDigital NZ is offline
Default MCpro Replacement motherboard needed
Our MCpro Advantech PCM-9587 SBC motherboard has failed.
The BIOS chip has failed and the motherboard will not boot up.
The PSU is at correct VCC = 5.05v
Tests have been done will all peripheral hardware disconnected, only KB and VGA display connected.
I have contacted Advantech, they have replied stating that they cannot repair the SBC. they also stated the the BIOS will only last 10 years, and we are well over that duration.
Is it possible to install a newer SBC?
What SBC's are compatible?
Can the AVID MCpro rescue installer be used?
Thanks
Ptle8.0 vista system-replacement motherboard advice montezuma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-30-2012 01:35 PM
Motherboard suggestions? (Intel Socket 775 - Asus P5B Replacement) Fireball71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-17-2011 06:08 PM
Best Replacement Motherboard For Quad Core Q6600 Build? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-24-2010 08:56 PM
Replacement motherboard for 001 with LE 5.3.1 tycho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-15-2009 05:49 PM
Accel Card with G4 Replacement Motherboard RocknReady Pro Tools TDM Systems (Mac) 0 04-08-2004 01:52 PM
