Windows 7 crash problems, mbox outputs not showing.
Hi all, I bought my mbox 2 pro 4 years ago now, ran it on a mac for 2 with only a few problems but then once the mac self desctructed in a big fireball (thanks apple) I decided to build a PC. Without the mbox plugged in it works perfectly, I haven't had a single problem that I can think of until the box is plugged in. I have posted on this forum before but have spent until now trying hundreds of options (and nearly bankrupting myself) in an attempt to make it work, but at least now I know a little more about it...So here's the list of problems it causes...
When I turn the PC on, I have about 5 minutes before it crashes. This happens every time without fail. The solution appears to be running some audio through the mbox and restarting the PC. When I do that it won't crash but there is a 1/50 chance it will select the right outputs- I am given the option of 1 or 2 random outputs, which usually seem to be 3/4 or S/PDIF so I then have no sound from my monitors. Another thing which is a bit odd is that there's a 50/50 chance of my wireless card not being found when the mbox is attached making me think the whole thing is a driver conflict. Today I had to restart 17 times (9 was the old record) so I decided I'd had enough, 1 restart is a pain in the arse as it is. I've taken the unit back to the shop (Novatech) and to about 7-8 repair shops as well as a few friends of mine and my old job where I was the studio tech guy (ironic, maybe). None of them have any idea whatsoever how to fix it and have all simply come to the conclusion that AVID are [bleep][bleep][bleep][bleep]. Now I'm not paying £35 for 1 phone call on the off chance they're not so any help from you lovely people would be greatly appreciated! I don't know what everyone else tried to fix it but personally I've tried disabling various things in the BIOS, reinstalling drivers for everything, updating all drivers, (this problem started with 8.0.1 and still exists on 8.0.4, on Vista and W7), wiping the PC completely and rebuilding it and kicking it. Next step if it doesnt work is to drive my car over the MBox and buy something useful that provides free tech support- sorry for ranting a bit but seriously paying for tech support...I spent £10k on a studio system I'm not paying even more just cos they sell me something flawed- without any obvious spec list to tell me components that would work or anything. Anyway here's a Sandra report, I can give any other info needed if it might help...what I ate for dinner, how far the PC is from Hull, that sort of thing. SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : SuperGoat-Thing User : The Blue Peanut Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus P6T SE BIOS : AMI 0608 11/11/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 6GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : Patriot Memory 1600LL Series 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-20 4-27-8-4) Memory Module : Patriot Memory 1600LL Series 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-20 4-27-8-4) Memory Module : Patriot Memory 1600LL Series 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-20 4-27-8-4) Video System Video Adapter : ATI Radeon HD 4800 Series (800 SM4.1 750MHz, 1GB DDR5 4x900MHz 256-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : ATI Radeon HD 4800 Series (800SP 750MHz, 1GB DDR5 3.6GHz 256-bit) STREAM Processor : ATI Radeon HD 4800 Series (800SP 750MHz) Storage Devices WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 628MB (D:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Renegade Game (D:) : 628MB (CDFS) @ HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Device : PC Partner Sapphire HD 4850 512MB GDDR3 PCI-E Dual Slot Fansink Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Wireless Adapter 1 : Belkin Wireless G PCI Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 5.9 Last edited by The Blue Peanut; 02-01-2011 at 01:13 AM. Reason: Info added |
Re: Windows 7 crash problems, mbox outputs not showing.
Maybe or maybe not related....where's your dedicated recording drive?
Not plugged in for now, I don't think it'll be related to that though since it's not just when pro tools is running. That does remind me of something though- When I first turn it on usually it'll find the right outputs but then I start pro tools up and the mbox stops registering any input or output. I usually have my guitar plugged into the front of it and the light won't even show to suggest there is any input once I start pro tools up. After restarting though this is fixed, it just loses track of which output to use instead.
More info that may be useful- when it crashes first time round and I'm playing audio sometimes it just stops but other times it seems to grind to a halt. It sounds as if the sample rates of whatever music I'm playing (Spotify/iTunes/Media Monkey) are being stretched out although the music doesn't slow down it just becomes gravelly and then eventually the whole PC freezes up. Possibly implies that the Mbox clock isn't working?
Severe MBox Pro Crash Problems | machete | macOS | 1 | 06-21-2012 07:58 AM |
M-audio firewire 410 not showing outputs in MP9 | Reggie TAE | Pro Tools M-Powered (Mac) | 2 | 04-23-2012 06:44 PM |
Mbox 2 mini not showing up in PT10 with Windows 7 | xcharlesx | Windows | 4 | 02-27-2012 02:56 PM |
Structure - Outputs Not Showing Up | dwaynedelario | Virtual Instruments | 8 | 06-20-2011 04:53 PM |
not showing outputs for saffire 24 dsp | bmenchen | Windows | 1 | 06-14-2011 10:17 AM |
