Help! I am picking up radio stations on when I record through my MBOX pro 3
I plugin my condenser ksm 9, i turn on phantom, turn up the pre, and boom there it is. radio static. i can practically hear what the talk show host is saying :P
i was trying to mic up my ac.guitar when i noticed it in the background. I tried moving things around since i thought it was power cables running over or close to my mic, mbox cables, but to no avail. Does anyone know how to fix this? is this a problem with the mbox, with my mic or with my xlr cable? thanks Nik |
Re: Help! I am picking up radio stations on when I record through my MBOX pro 3
Is all your gear grounded? (i.e. you're not using any ground-lift adaptors on your power cables or power strips)
If that's not it, I'd start with swapping out the XLR cable. |
It`s because your cable is unbalanced.
Niels |
http://www.monstercable.com/productdisplay.asp?pin=2312
These are the cables I use. Also, regarding grounding, could anyone guide me as to wht to do? Thanks for the replies guys NIK |
I think it`s maybe the wiring of the cable. If one of the connections has jumped of, the cable will pick up signals from the atmosphere like old guitars with unbalanced wiring.
Are all your gear plugged into the same electrical outlet?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Most likely, the mic cable is fine. Phantom power would not work(IOW, the mic would not work) at all with any bad connection. The mic works, but adds radio interference? Are you located near a transmitter? I would certainly try other mics(and other cables, just to be thorough). I would also try all(both?) mic preamps to see if maybe 1 works good, indicating some bad filtering on the bad channel(s). If that's the case, then you would likely get a warranty replacement from your dealer(you just need to be sure of the issue and cause).
Apparently same mic and same cable no problem at all on 2 out of four xlr inputs with the front #1 being loudest RIF and #2 just hissy. 3 and 4 in the back are just fine.
Im calling support asap:) thanks for the help people! |
I am having this same problem. What was the resolution? Was the hardware bad? Mic 01 is picking up the RF Modulation the worst.
There is also a lot of latency while recording in the headphones. Did you ever notice this? |
My Mbox 3 Pro Is Picking Up Radio Signals?? Help! | ssccurvemedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2013 11:14 AM |
only one headphone is picking up sound when i record | musicmaka420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-20-2009 12:09 PM |
DUC radio-stations | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-19-2005 10:45 PM |
OT: Methods for distribution to radio stations? | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-11-2002 12:19 AM |
Best radio automation program for professional radio stations? | GuitarEasley | General Discussion | 22 | 03-23-2002 11:32 AM |
