#41
Re: Pro Tools 10 on Windows 8??
I have Pro Tools 8 up and running with no problems at all .. Windows 8 has made my DAW so much more stable I can run as many rtas needed now with lil to no hiccups at all
#42
Hi Darryl
Been away for a bit came back and thought I'd try and install Pro tools again found the new 10.3.2 so I downloaded it completely uninstalled my PT 10.2 This is what is in my machine : Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz, 3501 Mhz, 4 Core(s), 8 Logical 32 8 GB 1333MHz DDR3 Non-ECC CL9 DIMM Kingston 2- 500 GB WD 7200 RPM 64 MB Cache HDD - SATA 3 - Black Edition 2- TB WD 7200 RPM 64 MB Cache HDD - SATA 3 - Black Edition 2- NVidia GTX 670 Video Cards Fire wire Card and MSI Z77A-GD80 Intel Z77 1155 4D.DDR3 V/L/S ATX main board Windows 8 version 6.2.9200 Windows sees my 003 just fine Install it and ran it in administrator mode It still does not work. Same error "Could not allocate memory for the disk cache. try lowering your disk buffer ( DAE Buffer). Disk cache size or engine voice count. I you got this error on launch , delete your prefs and try again ( -9514). There was nothing in the prefs folder … deleted it anyways … still didn’t work I am beginning to think Pro tools doesn’t like me ... So I thought maybe my 003 rack has a problem. I downloaded a copy of Mixcraft 6.1 a 75.00 Program !!!!! ... Picked it up right away ... no issues ... If this is how much work it takes to install … Not sure I want to spend the rest of life trying to use it. I am a big fan of using the industry standard stuff … this is why I went there in the first place … but not if it makes me crazy … Thank you for all your help ….. Let me know when and if Pro tools gets the windows installation part right. Pretty disappointed spent a few thousand dollars and to many hours just trying to get it to run on a windows. Sad , so very sad . Do you think I could get a refund? If so who would I talk to. I am one very frustrated customer Thanks again for your effort Mike |
#43
Windows 8 Release Preview
Ilok working on ilok.com and showing licenses 10.3.2 won't run, authorization error. Complete production toolkit won't install, can't find pro tools Any tips? I wanted to get 10.3.2 running on a backup computer (which is running windows 8 Release Preview) before upgrading my regular windows 7 system from 10.2 to 10.3.2. |
#44
Ilok problem was solved via this article:
http://avid.force.com/pkb/articles/e...ssage/en430451 DAE error by this one: http://avid.force.com/pkb/articles/e...ssage/en406391 Now I've got the "could not allocate memory for disk cache" error. I deleted my prefs, no joy. Don't know yet about complete production toolkit. |
#45
I don't understand the urgency to run ProTools on Windows 8. Much less the angryness and unsatisfaction some are declaring as customers.
ProTools is advertised as compatible with Windows 7, not Windows 8 yet. It will when Windows 8 is the standard. So, I don't see how someone can get angry at Avid because ProTools doesn't work properly on Windows 8 yet. Also, you get the most of ProTools you can get on Windows 7. If you're trying to use the latest version of ProTools because you want to use the "industry standard" for recordings, then install Windows 7 and use it. No real professional tries to use his Windows + ProTools setup to use anything else on it (e.g. more software, games, etc). More than that, he follows all the Windows optimization points described in the support pages, which make the system look less pretty but function pretty well. After all, that's the role of that computer, being a perfectly clean and fast ProTools platform. If you want to use the computer you have as ProTools Worstation for something else, then you can boot a different Windows (XP, 7, 8, anything you want) from a different partition or disk. That will protect your ProTools setup from getting dirty or misconfigured.
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
#46
If you want Pro Tools to run as advertised you need to stick to the stated spec requirements. Now if you are crazy, like me, and like flying by the seat of your pants and not having any support when something goes wrong, then install Windows 8
#47
I explained my "urgency".
I have no issues with running pro tools on a supported platform, I "want" to test 10.3.2 on another computer before I update my main system. If there are people here that have worked through the windows 8 problems I would like their help, because the only computer I can test on is windows 8. I am not demanding or angry. |
#48
I got passed the memory error somehow (can't remember what is was in the end). No audio would play back though when I imported audio clips. Then upon closing and re-opening Pro Tools it just crashes every time now.
It seems incredibly unstable in certain areas and fine in other areas (most plug-ins worked fine when I had the chance to test them). I've given up on it for the moment, I'm running it on my family iMac for the moment just to be able to do some uni work. (SIGH) |
#49
Avid Windows 7 Optimizations Video Playlist - YouTube Windows 7 Optimizations I know you are talking about Windows 8, but the list will be pretty much the same. also, you still need to always launch Pro Tools with Run As Administrator. http://protoolsquicktips.blogspot.co...using-pro.html
#50
I searched duc for all the disk cache error posts. The only fix I found (actually stopped looking after finding this) was running the installer as admin.
I tried that with no joy, after uninstalling and reboot. Today I installed the release version of windows 8 (using windows 8 upgrade tool), which I assume set me back to "zero" as no programs came across with the upgrade (only personal files). Tried again to install Pro Tools as admin but I'm still stuck at the disk cache error during startup. Yes I know there's posts saying that installing protools 9 and then uinstalling works but I don't have access to PT 9 installer anymore. |
Pro Tools 11 on Windows 7 or Windows 8? | ianbee | Windows | 6 | 08-15-2013 04:04 PM |
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) | miek07 | Windows | 3 | 07-26-2012 07:49 PM |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system | rhodamorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 05:31 PM |
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2009 08:24 PM |
