Old 10-30-2012, 12:06 PM
T.Glaze T.Glaze is offline
Default midi controller not working?
hello all,
haven't used my oxygen controller in a few months,
worked fine last time i tried.
controller works when i open some plugins in stand-alone mode like kontakt or minimoog v original.
today, not responding in PT.
running PT 8.05
my mac is running 10.6.8
tried several instruments like vacuum or mini grand
and they work in the session,
just don't recognize my controller.
how do i trouble shoot?
where do i reconnect the midi controller?
thanks for any help.
terry
Old 10-30-2012, 05:22 PM
earshatter earshatter is offline
Default Re: midi controller not working?
Originally Posted by T.Glaze View Post
hello all,
running PT 8.05
terry
Here's what I would try:
MAKE SURE your MIDI thru is active.
In PT Prefs, MIDI, under BASICS, make sure your "Default Thru Instrument" is assigned to either it's own instrument channel, or select "first selected MIDI track".
These may help you. If that doesn't work, go into your Utilities in your Applications folder under "Audio Midi Setup" and check your settings there. Your Oxygen should show up. If not, add the instrument you need.
Good Luck.
Absence of evidence is not evidence of absence...the truth is out there.
Old 10-30-2012, 09:31 PM
checked everything that was recommended,
no luck yet.
controller works with plugins in stand alone mode,
does not work when open plugins in pro tools.
t
Old 10-30-2012, 10:22 PM
no luck yet.
t
I forgot to mention (just in case) make sure your drivers are updated for your controller in case PT looks for a different driver. Just a thought.
Also, make sure that you are using an "instrument" track for your controller to operate. ie: if you have soft synths/samplers/Reason/etc, those have to be on an instrument track...in case you haven't done that, but you probably have.
Old 07-06-2015, 02:31 PM
bullemore bullemore is offline
I had the same problem and I solve it using a powered USB hub, I connected my usb keyboard (m-audio prokeys 88) to the hub and connected the hub to my mac (retina) then everything works, Im using pro tools HD11, and OS X 10.10.4
Midi Controller not working davgrn Windows 2 12-01-2013 01:59 PM
Midi controller not working! SonnyT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-31-2011 04:10 PM
midi controller not working with ez drummer alzuka MIDI 3 08-18-2009 07:50 PM
Midi Controller not working Precava Pro Tools TDM Systems (Win) 7 12-11-2005 12:01 PM
USB MIDI CONTROLLER NOT WORKING NickFLZ Pro Tools TDM Systems (Mac) 7 07-08-2003 08:48 PM
