Old 01-07-2020, 03:15 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Replacement Faders (all created equal?)
I've purchased a couple of replacement faders from eBay, and have had great luck. They're usually between the $75-$150 range each. Are they all the same? See the following links and varying prices.
Actual D-Command fader
Set of 5 for $50
About $20/each
I see the wiring diagram on the sides. As long as the appropriate wires are connected to the appropriate numbers, would these work in a D-Command if they're the 10KB model?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-08-2020, 07:30 AM
Default Re: Replacement Faders (all created equal?)
I'm not the final word on this by any means, but did you notice some are 10KB and some are 10KA? Guessing here, but the A and B might refer to different tapers(so maybe see if ALPS has a site and support area). It might also be worth a phone call to an Avid-approved service center. Allproelectronics (allproelectronics.com) in Nashville, TN is a shop I have used in the past.
Old 01-16-2020, 08:21 AM
TheFilterLab TheFilterLab is offline
FYI The link to the 10KA faders are not going to work. They are for an analog console. You'll notice they have no motor! Don't but those for an icon.
Old 01-16-2020, 08:23 AM
Ryan Young's Avatar
Thanks all. 10kb looks ok though?
-Ryan Young
Additional Systems
Old 01-17-2020, 05:43 PM
Ryan Young's Avatar
I bought the two 10kb bundles. I compared the wiring diagram with my existing faders, it looked the same. I'll experiment once I get them and keep my fingers crossed! Thanks for the help everyone.
-Ryan Young
Additional Systems
Old 01-21-2020, 02:08 PM
Hey Ryan,
Sorry I didn't see your other post. It looks like the faders you got might be the ones from a venue console. If that is the case you might need to move some of the pins on the connectors to make it work with a D-command or D-Control. I don't remember exactly which pins but you should be able to figure it out by comparing them to one of your stock faders.
Good luck,
Jared
Old 01-27-2020, 08:03 PM
Ryan Young's Avatar
Hi Jared. You're absolutely right. The connector is 8 pin on most of those, and the D-Command uses a 6 pin. Everything else looks identical. I did some researching and I think the connector is called a micro JST 6. If I got the wrong size, I'll exchange the following purchases I made:
I picked up a few of these
And I picked up a few of these
I'll try to either change out just the tip or change out the wiring from the fader itself.
I got a "broken" D-Command for free. It has 7 faders in it, one without a cap. It is given "as is", and I figured I'd take a stab at fixing it, where needed. If I end up destroying it, no harm no foul. WHEN I fix it, AWESOME!
The funny thing is one of the faders in the bunch has the correct tip!
-Ryan Young
Additional Systems
Old 01-28-2020, 04:41 AM
crizdee's Avatar
crizdee crizdee is offline
You might find the twin JST connectors fit so could use 3 of these per fader and just copy the wiring etc...
https://odseven.com/products/2-pin-j...c-wires-cables
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-29-2020, 11:57 AM
Ryan Young's Avatar
So, I totally got the wrong size! lol. The ones that arrived are half the size needed. I'm going to order the pairs and go from there. #noob
-Ryan Young
Additional Systems
Old 01-29-2020, 02:42 PM
Hey Ryan,
Lucky you, that's a big score!
When I got mine I had to do a bunch of work to bring it up to speed too. Feel free to send me a direct message if you have more specific questions. Also, I think I have some spare fader caps depending on what kind you have. Let me know if you are interested.
Take care,
Jared
Are all ADAT ports created equal? Premo Pro Tools TDM Systems (Mac) 3 08-12-2008 08:17 PM
ALL midi cables created equal? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-24-2006 05:02 PM
Not all 9073's are created equal! PT IS RIGHT! anakinskye2769 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-08-2003 02:36 AM
Are all FW drives created equal? Nashville Bass Storage Subsystems 0 02-14-2003 06:42 AM
