importing session data question/problem
I have several live songs im mixing and want to use the same mixer setup/plug-ins for each song. (since they were all recorded in the same night). What is the most efficient way to accomplish this? Would i Import session data from the 1st mix i do? Also, when i attempt to use the import session data function, the dialog box that opens is too big for the screen and i cant move it far enough to access the "ok" button...weird... Im tired of re-setting up a new mixer for each session..please help!
Re: importing session data question/problem
Try creating a new session, then importing everything except for audio and automation from your first mix.
Save that session as, for example song 2 or whatever then import audio from the second song and make sure you select "link to original" and not "copy or consolidate from original. Finish your mix and do it over again on the next song naming it song 3 or whatever. Your problem with the OK button could be solved by increasing your screen´s resolution. If that is not possible, try hitting enter when done making your selections in the import window and if that does not work, hit TAB and then enter until the window goes away (a work around)
"Ok I promise, this is the last plugin I´ll buy!" www.syrland.is www.sturluson-music.com |
Thank you...ill let you know how i make out!
8.01 Importing Session Data BUG | TimNielsen | Pro Tools TDM Systems (Mac) | 0 | 10-30-2009 12:04 PM |
Importing Session Data? | MOYMOYMOY | Tips & Tricks | 2 | 05-10-2008 01:20 PM |
Importing Session Data Question... | kravinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-28-2008 04:45 PM |
Problem Importing Session Data | garnoil | Pro Tools TDM Systems (Mac) | 6 | 11-19-2007 03:27 PM |
Importing Session Data problem | Sadie Tango | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2007 06:37 PM |
