Old 02-01-2018, 07:52 AM
Thomas Demman Thomas Demman is offline
Default Uad Plugins stopping audio in PT subgroups
Has anyone experienced this problem ...please I cannot be the only one ...the problem has happened on 2 different computers ...now in Sierra and 2018.1
Something is blocking the subgroups....reverted back to 12.8.2 and now the problem persists ...I have thrown out all preferences from PT and Uad many of times ...the problem has slightly improved but is not stable ...UAD insists it is not their problem....now has anybody had this issue....I can’t imagine being the only one ....any other info that you need please feel free to ask....I am a open book at this point ....yes I have filled out a support ticket ....one in November and the problem was fixed from going Sierra ....12.8.2 and a 1000 dollars .....now updated to 2018.1 problem is back
Even after reverting back to 12.8.2....the problem of audio getting thru at times is intermittent......when something’s not broke ...don’t fix it...can I get some help ...I’m out of straws till avid contacts me once again ...even then they are puzzled ...
Old 02-01-2018, 07:57 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Uad Plugins stopping audio in PT subgroups
List all system specs.
List all interfaces used
List all UAD DSP used and the connection type.
Post screen shots of your routing and "audio blocked" problems
Direct screen shots (in focus please) inside your session.
also screen shots of the plugins gui open
Daniel
Old 02-01-2018, 08:02 AM
Drew Mazurek's Avatar
Heavy UAD user here, not seeing this.
www.drewmazurek.com
Old 02-02-2018, 05:35 AM
Tobias Eichelberg Tobias Eichelberg is offline
What kind of hardware are you using exactly?
I never experienced anything like that either.
Old 02-02-2018, 02:40 PM
jjnssn jjnssn is offline
Not having and issue here with PT 2018.1, UAD, and 10.13.3.
Old 02-06-2018, 06:38 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
No problem here either on Windows 10 with PT 2018.1 and UAD 9.4...to be truthful I never heard of a UAD problem like this.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 02-06-2018, 06:43 AM
abc1mce2's Avatar
Are there other plugins (besides UA) on those tracks or sub groups that might be running in demo mode?
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 02-12-2018, 07:52 PM
After being on the phone with avid 3 hours one day and 3 hours another ....they define my issue as a resource issue and I’m running out of resources ....which transalates into needing 32 more gigs of ram ....total of 64 .....if you close the file and load the same file it does my explained problem.....if you quit Protools and then load the same file ....everything works fine ...the avid tech said and also My LA tech say the same thing .....more ram could cure the issue ....my tech from LA says as common practice he quits Protools before every song so he gets that maximum amount of resources out of his cpu...again if I quit Protools for each song ....now mind you these are pretty serious track counts.....75-100 tracks ......small files do not do this only big ones and it’s not just uad plugs ....it’s everything and anything native .....dsp works fine .....so there you have it .....please fire away with your cures and fixes .....and thank you most of all for taking interest in my dilemma
Old 02-13-2018, 05:45 AM
In the absence of full system info (you only have a small subset in your profile) and making some guesses it looks like you have the dual cpu version of my cheesegrater (2012 with a single 3.46 GHz cpu; I have 48 gig ram). That means your UAD connection is FW800 - have you tried connecting to the different FW800 ports on the Mac? Do you have anything daisy chained with the UAD?
How is the ram set up? Is everything of the same size/specs? Do you have all 8 slots filled? Remember that Macs of this vintage use triple channel ram and the optimal setup is to just fill 3 slots on each side with ram.
What are you using for a system drive? Spinner or ssd and if ssd is it in a drive bay or on a pcie adapter card?
Jack
QAPLA!
HTML code is On
Subgroups for a piano or strings? bryced87 macOS 2 04-22-2013 06:43 AM
Audio stopping while recording stratevcaster Pro Tools 10 5 03-15-2013 10:27 AM
Aux Sends from Subgroups Duardo VENUE Live Sound Systems 4 01-29-2006 08:29 AM
Stopping a session from searching for missing audio electricbs Pro Tools TDM Systems (Mac) 3 07-10-2002 09:05 AM
Stopping a session from searching for missing audio electricbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-09-2002 09:34 AM
