Delay Compensation not working
I've been using PT 12 since it was first released without issue. Recently I am intermittently having automatic delay compensation issues. I notice that the snare starts to flam. When I turn off the overheads the flamming stops. If I turn off all plugins there is no flam even with the overheads are on. Zooming in on the waveforms shows that the overheads are not out of alignment with the snare.
The the problem will then disappear all of a sudden and everything is fine for an hour. Then it returns. This happens without me doing anything I'm aware of. I cannot track it down to any plugin in particular. Does anyone one have any idea what could be causing this? Thanks. |
Re: Delay Compensation not working
It appears to be a bug in PR 12 Native. I found that when I hide and make inactive an aux while a song is playing back, it seems to break the automatic delay compensation. Even after reloading the song or restarting PT the problem sometimes persists. The suddenly it will disappear.
Mac Pro 12 core 3.06 GHz, 24 GB RAM. OS 10.12.5 RME Fireface UFX II Pro Tools 12.0 |
That sounds not fun at all.
Is there a way you can provide detailed steps to reproduce the problem? Perhaps by creating a new session some minimal steps to make it happen? If so, we might be able to help narrow this down, collectively and submit it to tech support. |
Hi All, I am new to the forum but been using Pro Tools a few years. I came across a possible bug in Pro Tools 12.8 I have been able to reproduce the error on a different system and a different project. As it relates to this topic (I can't start a new thread) I will post it here.
The root of the issue: A virtual instrument, let's say drums, is receiving notes from a midi track. quantized. On another track a plug-in is inserted , a plug in that causes Delay Compensation to kick in. Everything is a ok during playback. However: when I freeze or commit the virtual instrument, the timing is completely off. I tried realtime bouncing but no luck. The only workaround is to make all plugins that have ADC inactive (so there is no actual ADC) then a commit is working properly. I have reproduced this on 2 different new installed Mac systems with different sound devices and with a pro tools 12.7 project (that didn't have the problem). I even created a new project in 12.8 with a: - miditrack containing a few notes routed to - A virtual instrument track , let's say the piano - a third audio track , no audio, just insert a plugin that causes the ADC to work then freeze or bounce: you will immediately notice/see the delay between the midi notes and the wav files from the frozen track. Any help on this matter ? I am happy to provide the test-project. BTW this is just protools 12.8 on a Mac not the HD version Last edited by henkschenkworst; 08-04-2017 at 11:14 AM. Reason: addition & correction |
Hi John1192,
Thanks for your reply. Ok, a bug it is. I am currentlly uninstalling 12.8 and reinstalling 12.7.1 Strange this hasn't been tested, Pretty basic functionality, I mean in addition to my post, not only the track freeze isn't working: bouncing the whole project isn't working either. To be honest I wonder what the heck 12.8 is out for ? It only brought me this showstopper and 0 usable features. No problem with the subscription model, I am a happy pro tools user for years, no complaints here, but lately the new releases practically contains nothing but hot air and new bugs. |
i feel like they have trying to get this Business Model to get better and better .. unfortunately all we can do is have patience and try and give them some support by Reporting Bugs in Support Cases .. if i did not need to use pro tools i might not .. but my business requires it .. so i use it for that part .. and if i want to use something different for other projects sure ... i just like it still !!!
For the most part, ADC works fine here. The 2 times it does not are"
1-if I have a send(on any track) assigned to a bus that goes nowhere(like if I have a send feeding an AUX track with a reverb or delay plugin, change my mind and delete the AUX track, but still have the send in place). That will cause some tracks to have almost 2000 samples of compensation that doesn't belong. 2-If I route a VI(like Superior Drummer) to record as new audio files; things will flam badly during the record pass. Once it finishes, playback sounds fine.
Hi Albee,
the ADC is not working. It's reproducible: 1. create a VI track with the piano 2. create a midi track routing some notes to the VI track 3. add an audiotrack and insert any plug in that needs ADC 4. playback is fine 5. freeze/commit and you'll notice the timing is off. |
Hope they will improve on their testing procedures too. this really sucks. cheers from Amsterdam ! Last edited by henkschenkworst; 08-05-2017 at 03:28 AM. Reason: edits |
Delay compensation not working right on inputs? | Luigi2000 | Pro Tools 12 | 10 | 10-03-2015 01:29 PM |
Delay Compensation working in reverse??? | Eric Lambert | Pro Tools 10 | 12 | 02-09-2015 08:15 AM |
HD Native Delay Compensation not working! | nuancerec | Pro Tools HDX & HD Native Systems (Mac) | 10 | 01-24-2011 04:12 AM |
Automatic Delay Compensation not working like it should | Edgur | Pro Tools TDM Systems (Mac) | 8 | 08-19-2009 07:25 AM |
Delay Compensation Has Stopped Working | voce | Pro Tools TDM Systems (Mac) | 5 | 07-08-2009 12:32 PM |
