Plugin's loading problem on Pro Tools 11
I've installed my Pro Tools 10.3.7 and 11 on my mac and then started installing all my plugins. when the process was done I've opened the 10.3.7 version and everything worked.
but when I tried to do the same in Pro Tools 11 the loading ended in XPand2 and went right to the open dialog without my external plugins. the native plugins did load up and work fine.. Please help..! |
Re: Plugin's loading problem on Pro Tools 11
I use an 17" Retina mid 2012 MacBook Pro 2.6 quad core i7 with 8gb ran which runs on OSx Lion 10.7.5
Pro Tools 11 Ignores every plugin I have.. I use Cubase 6 with 64 bit and the plugins seem to work just fine. I was not aware of aax.. I thought RTAS was just for PC because from what I understand Mac uses DPM... correct me if I'm wrong So you say I need to update my files? they are actually pretty old versions.. Last edited by nickLime; 10-08-2013 at 09:32 AM. |
Yes - you may well have to update your old plugins. You haven't mentioned what plugins you have. They may not even have aax 64 bit plugins like nothing from Native Instruments has aax 64 bit, only aax 32 bit which won't work in PT 11. |
actually I only have PT for 6 months. and I just got my Mac for one month so I'm still new in that area....
thank you for your help though.. I'l try to find better versions for the plugins that I already got. I guess I'll keep working with Komplete via PT 10.. too bad |
Problem loading Pro Tools in 10.1.2 | pianosdr | Pro Tools 10 | 4 | 05-12-2012 12:09 AM |
Problem loading Pro Tools 9.0 | csm2 | macOS | 3 | 10-03-2011 05:58 PM |
Problem loading Pro Tools 8.0.1 | sajamie81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-14-2010 12:26 AM |
Pro tools 8 + VST loading problem | maximoments | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-28-2010 01:14 PM |
Problem with loading Pro Tools | LaurentRenders | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 07-29-2009 06:51 AM |
