Imported Quicktime video plays back too fast
After importing a Quicktime video and setting it to the correct frame rate (29.97 fps) the video plays about 5 times faster than it should. I hope there is an obvious solution to this - I haven't been able to find a clear reason why it's happening. The imported audio, however, sounds fine.
I used Gspot and it says the file's codec is avc1, named H.264. |
Re: Imported Quicktime video plays back too fast
Dev |
So, I tried transcoding the file to Avid DNxHD, imported video into PT and got the same problem. (Since I am new to working with video, I found this method to transcode the video file: http://buildyourown.wordpress.com/20...ode-mov-files/ ) I also tried transcoding the file to Avid DV, which also produced the same sped up result. Any thoughts?
I would assume that an Avid DnXHD should work fine, but I don't have much experience with this type if codec and ProTools. We used ProRes Proxy's almost exclusively. Can you confirm that when you play this file in QuickTime (original) that it doesn't have the same issues? Anyway to get this file re-outputted in a usable file format from wherever your getting it? MPEG Streamclip is great, but it's easy to transcode wrong, as there are lots of options. Just a thought. Short of all that, make sure you give the system a fair shot, by deleting all relative Prefs and .plist files (including the QuickTime prefs), and a permissions repair. Dev |
Burned CD plays back too fast!!!!! | mikel92009 | Windows | 4 | 02-18-2014 10:14 PM |
Imported audio plays too fast? | Quinn9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-13-2010 01:07 PM |
when i record it plays back too fast! | jharms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-14-2007 11:58 AM |
CoreAudio manager plays back fast | Irl Sanders | Pro Tools TDM Systems (Mac) | 3 | 10-06-2006 10:35 AM |
Plays back audio too fast | MidnightFlyer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2003 05:18 PM |
