Old 07-23-2012, 12:46 PM
willl3 willl3 is offline
Default ASIO4Alll audio is computer out of computer speaker and not rear speaker
how do you change this
sound like its coming out of the headphone jack in front as my speakers are connected and work from the back.
Why and how can I fix
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 07-24-2012, 08:58 AM
Default Re: ASIO4Alll audio is computer out of computer speaker and not rear speaker
WoW all those views an no response.
Seem something in my hardware but asio sucks as if I even go into it it shuts down protools even when I havent made any changes
again sound is coming out of the internal computer speakers and routing it to rear speaker output.
What do I do?
Old 07-24-2012, 09:47 AM
necjamc necjamc is offline
Default
That might be an issue within windows itself. I'm not in front of my computer right now but right click the volume icon bottom right of the screen. (or is it double click). Anyway, open the controls for playback, recording etc. select whatever you want to use as the default. You might want to disable any other ports as to make it easier if you can.
It's not the best explanation, so if you get no more responses before I'm in front of my computer again, I'll check it out myself at home to tonight.
Old 07-25-2012, 07:45 AM
weezul weezul is offline
you need to make sure in ASIO4ALL that you've selected the correct outputs. With pro tools open, the icon will be in the tray. Double click, expand the sound card on the left hand side and make sure you select the correct output. Disable any you won't be using. Pro Tools will spit its dummy and then just restart it and it should work :)
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 07-25-2012, 09:20 AM
soybalm soybalm is offline
Make sure you click the wrench icon in Asio4all control panel so you can expand the input/output panel and edit what's on, and yes, reboot Protools. I hate that. Most other programs just relaunch the drivers. I remember when Logic PC added that feature in 97' maybe? 15 years ago.
Old 07-25-2012, 03:20 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah and don't forget AISO won't go past 48khz sampling rate......
Daniel
Old 07-31-2012, 10:50 AM
Si i fixed it
downloaded Reakltek HD changed the setting so the audio goes out the back output of the computer
Problem with Speaker Configuration in Audio Midi Setup HB123 Pro Tools HDX & HD Native Systems (Mac) 0 01-18-2014 02:44 PM
Aggregate I/O Built-in Speaker causing speaker to crack and pop andrewkeithly macOS 2 01-27-2012 11:10 AM
Protool 9 ASIO driver sound out of computer speaker willl3 Windows 2 04-06-2011 06:58 PM
XP Outlook error and computer speaker non-function rodefer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-03-2010 05:25 PM
Speaker distance to computer drummer9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-17-2009 11:21 AM
