Old 01-26-2012, 06:55 PM
andrewkeithly andrewkeithly is offline
Default Aggregate I/O Built-in Speaker causing speaker to crack and pop
I have been utilizing the Aggregate I/O setup to record a guitar track, via Mbox mini input while monitoring via my computer built-in speakers.
While this sometimes works just fine, after a while my speakers begin to crack and pop.
I have checked my speakers to see if they were causing the problem, however they seem to be in working condition.
Also, If I reopen the project the speakers may playback normal for a while, they eventually start to crack & pop.
I think it is worth noting that my levels are set well below anything that would cause my speakers to pop due to level.
Any information on this would be much appreciated!
Old 01-27-2012, 08:00 AM
priorytools priorytools is offline
Default Re: Aggregate I/O Built-in Speaker causing speaker to crack and pop
Check your clocking in audio midi set up .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-27-2012, 11:10 AM
Alright, so I reset my Master Clock to the Built in output (instead of the mbox) and everything seems to be working now.
I didn't even think to check that.
Thanks for your help!
Aggregate I/O and Built-In Mics mgtube Pro Tools 9 10 09-03-2015 12:13 PM
ASIO4Alll audio is computer out of computer speaker and not rear speaker willl3 Windows 6 07-31-2012 10:50 AM
Flat Panel Causing Speaker Humming Help Needed!!! Cuzson General Discussion 0 08-21-2007 01:37 PM
Flat Panel Causing Speaker Humming Help Needed!!! Cuzson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-21-2007 11:53 AM
5.1 speaker set up bbob Pro Tools TDM Systems (Mac) 4 06-27-2006 09:13 AM
