Old 02-27-2008, 10:02 AM
Rooster777 Rooster777 is offline
Default \"...unable To Reacquire Hardware...\" Help, please!!
Since I've been using this software, I've been able to import audio from my hard drive or a CD. Now, whenever I try to import anything I get the message:
"Pro Tools is unable to reacquire hardware because it is in use by another program. Please quit that program and then hit 'OK'. If the hardware can't be freed, Pro Tools can't continue to run. In this event, hit 'Quit'."
I have nothing else running! This happened slowly. First I couldn't import from the hard drive, now I can't even import from a disc. No matter what format.
At that point, I have to hit "Quit". Then I get:
"Pro Tools hardware is either not installed, or in use by another program"
Then it tells me I may have to reboot to use Pro Tools again.
I'm sorry to bug you guys with this, it's just really becoming a problem.
Steve.
Old 02-27-2008, 11:12 AM
DigiTechSupt's Avatar
Default Re: \"...unable To Reacquire Hardware...\" Help, please!!
Is your Sound control panel possibly set to use your M-Audio hardware? If so, try changing it to something else before using Pro Tools.
Let us know if that helps.
Also, you may also want to look at all the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread.
Avid Audio Tech Support
Support FAQ
Old 02-27-2008, 12:10 PM
Amazing! That was it. I set it to use a different sound card for playback and now it works.
You are a genius!
Thank you SO much.
Steve.
Unable to reacquire hardware [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-22-2019 06:50 AM
Unable to reacquire hardware and DAE error 6117. Please help TheSmackPanda Pro Tools 10 2 06-16-2015 02:02 PM
Exiting playback engine! PT unable to reacquire hardware crizdee Pro Tools 10 1 12-17-2011 03:28 AM
unable to reacquire the hardware! "MDW" The cause crizdee Pro Tools TDM Systems (Mac) 4 01-23-2006 06:09 PM
Unable to reacquire hardware.... Mark Tandy Digidesign Hardware & Software 4 06-07-2001 03:55 PM
