Calibrate the faders ?!
My fader number 8 seemed to not be calibrated ok, when I have 8 tracks activated so the last fader is "online" it flies up and down on time per second or something, between 0db and -3db or something, I dont see it in protools or in volume at C8, just the physical fader is crazy. And when I set it at top I just have +7,5dB, not 12dB as the others. I have just upgrade the firmware but it didnt help, before I had +8.6dB at top and now +7,5dB so something happend.
When I turn it off and on it seems to calibrate all faders correct, I have no errors. But the problem still remains. Is there a way to calibrate the faders or do I have to send it back? |
Re: Calibrate the faders ?!
You can reset the faders, essentially calibration. Very simple procedure. Just check out the C8 manual for all the utility functions.
I believe it's something along the lines of F1 utility -> Fadcal (channel select 1) and then it does it's thing. Press channel 8 select switch to exit. I notice after about a week of constant use the C8 faders start acting a little goofy. Therefore I run this calibration about once a week. |
I tried that but that calibration doesnt fix the problem. I notice that all the faders goes up to a value of 1023 except for the fader 8 that only goes up to 930 when I runt "test faders". And in the middle all the others have value 510-511 and fader 8 has 460. It would be great to manually set the high value to 1023 :/
How to calibrate 96 i/o | EarHole | Pro Tools TDM Systems (Mac) | 3 | 06-06-2009 09:26 PM |
I DON'T want to calibrate my room | dmfisher1 | Post - Surround - Video | 2 | 01-21-2005 11:21 AM |
calibrate i/o | DeadboysThing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-24-2003 07:41 PM |
Can't Calibrate Outputs on my 888/24 I/O | Obostic | Pro Tools TDM Systems (Mac) | 4 | 11-27-2000 06:02 AM |
How often do you calibrate your 888's? | Anibal | Tips & Tricks | 0 | 02-08-2000 08:33 AM |
