Old 04-13-2006, 09:54 AM
StaticStudios StaticStudios is offline
Default All LED Displays Are Dimming Randomly
I'm Running a TDM HD3 system on a Mac G5 with procontrol, edit pack, and expansion fader. Every so often the LEDs on the main unit will start to dim and the main unit loses communication with protools prompting an error message. There doesn't appear to be any sort of pattern to this so I have to assume that it has to do with the motherboard or the power supply. Has anyone else experienced this, and if so how was it resolved?
Thanks
Static Studios
www.staticstudios.net
Old 04-13-2006, 11:39 AM
Roy Pahlman Roy Pahlman is offline
Default Re: All LED Displays Are Dimming Randomly
I never had dimming LED's but I sometimes lose communication with the ProControl. When this happens, it is our G5 losing communication with the network. I have to shut off the G5, disconnect the network Cat5 from the G5 and restart. I then shut down the G5, re-connect the Cat5, and start the G5 again. This wakes the Mac up to see the network again, and the ProControl magically works again. Full power down and power up was needed to make the G5 wake up properly to see the network. Don't know if this your problem, but it worth looking at.
Old 04-13-2006, 05:55 PM
RobMacki RobMacki is offline
You've checked the sleep prefs on the main unit?
Or does this happen while active?
Old 04-27-2006, 05:31 PM
Camilo Orozco's Avatar
Camilo Orozco Camilo Orozco is offline
Hello,
I had the same exact problem a few years ago, it was the power supply.
my .02
Camilo Orozco
Like us on www.facebook.com/artedigitalestudio
www.estudiodegrabacion.com.mx
Hello,
my .02
Camilo Orozco
Old 06-05-2006, 12:44 PM
Yes, it happens while active. I've also reset the firmware and for the last month or so the problem seemed to go away. It's back again, and the firmware reset isn't working. Also there is a new glitch: When the ProControl starts dimming, the faders will, in unison, move up and down so fast that there is an audible slamming sound.
I'm almost certain that it's the power supply. Camilo, did your faders have do the same thing?
Old 06-06-2006, 08:28 AM
matmi's Avatar
matmi matmi is offline
http://www.digidesign.com/index.cfm?...19&itemid=4915
Audio Profesional Ingenieria en Audio Profesional
Betunias No. 13, Jardines de la Florida
Naucalpan, DF 53130
Phone: 52-55236-3482
Email: [email protected]
Old 06-06-2006, 09:57 AM
Tweakhead Tweakhead is offline
It is typically dry solder joints on the main power smoothing capacitors. I had mine fixed and posted my info about this in another thread:-
________________
I was suffering from this same problem, and had it fixed by an excellent tech by the name of Greg Granieri (most recently Chief Tech at O'Henry Studios). He has a great deal of expertise with Digidesign products. He can be contacted by phone at (818)-425-1053 or email to [email protected]
________________
I am sure someone in your area can fix this if they are an experienced tech with Digidesign products.
Mackie defective MCU dimming issue Lawsuit lordtom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-23-2011 06:39 AM
Lights dimming tlamb VENUE Live Sound Systems 1 12-16-2007 01:15 PM
1 display, 2 displays ..3 displays? what would you DHG MUSIC Pro Tools TDM Systems (Mac) 12 10-23-2006 08:59 AM
Dimming the Screen While listening? brinaddison Pro Tools TDM Systems (Mac) 7 03-23-2005 11:25 AM
RANT: Dimming talkbacks prockmat General Discussion 1 01-14-2005 02:00 PM
