  #21
Old 03-14-2019, 02:07 PM
ChuckS ChuckS is offline
Default Re: Getting Pro Tools to recognize USB-MIDI Interface - Setup
Originally Posted by buddyrocker View Post
AMS looks good and the above instrument track should be good. The second instrument track you set up is useless for Mini Grand. You are sending the MIDI back to the XP. The XP IS NOT configured as a controller in peripherals like you tried to do with the USB, right? It should not be. And, it is enabled as a MIDI input device in MIDI Setup? What channel is your XP transmitting on?
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
  #22
Old 03-14-2019, 02:13 PM
Also you should not have anything configured in Peripherals. If you still have the USB adapter configured there, get rid of it.
  #23
Old 03-14-2019, 03:04 PM
YYR123's Avatar
YYR123 YYR123 is offline
That runs off USB 2.0?
Yes USB has more than enough bandwidth to support midi.
I found it helped my connection issues and it helped my midi latency issue (which I didn’t even know I had)
Daniel
  #24
Old 03-16-2019, 11:10 AM
AE AE is offline
chuck is correct, you should not have a MIDI peripheral defined—that's for stuff like console controllers. AMS establishes the MIDI routing for the Roland.
shouldn't your Roland be showing up in your MIDI Input list? the fact that it isn't is suspicious to me. you should double-click the Roland icon in AMS to see how it's configured.
i'm also suspicious of the cable interface you purchased. that could certainly be causing problems. do you know anyone who owns an old-school interface? (a box with 5-pin MIDI inputs and outputs and USB on the other end.) would be helpful to swap out that cable interfacer to see if it's the culprit.
PT will not recognize my MIDI interface [SOLVED] JMUMRD MIDI 3 05-19-2015 04:17 AM
Pro Tools won't recognize interface. wedgewedge Pro Tools 10 3 04-30-2014 11:55 PM
Pro Tools 9 HD won't recognize my 192 interface innerbooty Pro Tools TDM Systems (Mac) 12 11-17-2013 01:39 PM
PRO TOOLS 10 + HD2 + 96 IO interface not recognize eliomusik Pro Tools TDM Systems (Mac) 14 09-28-2012 11:34 AM
Audio/midi setup doesn't recognize my mbox 2 academic? jpp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2009 10:49 PM
