Old 11-11-2018, 08:26 PM
amscheme amscheme is offline
Default Plug ins
Running pro tools 7.3, I just got the wav bundle of plug ins install to my computer was successful but they don’t show up in my pro tools. Do I need to move them into a certain folder or do something different or maybe they’re not compatible with my version of pro tools I’m running, can anyone help?
Old 11-11-2018, 09:55 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Plug ins
Really you should try telling us less info....
Help us help you - READ THIS before posting!
https://r.tapatalk.com/shareLink?sha...0&share_type=t
Daniel
Old 11-11-2018, 10:04 PM
BScout BScout is offline
Default Re: Plug ins
I’m assuming you mean “Waves” as in Waves the company. If you got any of their recent versions, then Pro Tools 7 isn’t supported. Not for a long time. You should have checked their system requirements. Especially since you are running software almost 15 years old.
If you bought a plugin bundle that was developed a long time ago when 7 was still current (Waves Gold for instance), you might want to contact them to see if they can migrate your license to a version supported by Pro Tools 7. But most likely it was something protected by ilok which means they can’t do it since they don’t use ilok anymore.
Old 11-12-2018, 09:37 AM
Andre Knecht Andre Knecht is offline
Originally Posted by BScout View Post
[…] since they [Waves] don’t use ilok anymore.
Actually they do. Current authorizations can be placed on an iLok, a removable USB stick, or on a drive. The choice is left entirely to the user.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 11-12-2018, 10:21 AM
YYR123's Avatar
Yeah on that note I have HD8 license for sale with HD3 PCIX if your interested
Low latency tracking still some of the best stuff out there
Daniel
Old 11-12-2018, 10:23 AM
IHTH.
Wrong.
iLok has not been supported for a long time. The whole point of Waves going to their own licensing scheme (USB stick or hard drive/computer) was to get away from Pace/iLok
https://www.waves.com/support/authorize-ilok
And that link also seems to eliminate the possibility of a downgrade to a Waves shell supported by Pro Tools 7 so unfortunately the OP is out of luck.
Old 11-12-2018, 11:52 AM
There's been a number of posters asking for help here the last couple of days who can't be bothered to give any kind of system info. That just wastes our time and leaves the questioner without getting their problem solved.
Old 11-13-2018, 01:06 AM
VRW VRW is offline
1st of all, like all the others mentioned already, you have to leave more detailed info regarding your whole system here. Otherwise the DUC guys are not able to help you further in a decent way.
2ndly according to your sparse info you are on PT7.3 which theoretically means that you are still on Mac OS 10.4 (given you have your version of Pro Tools installed on the compatible version of Mac OS).
This means further that you would need Waves version 6 to be compatible with your versions of Mac OS and Pro Tools. Anything else probably won't work properly.
Check it out there:
This was copied from the Avid requirements site
"Pro Tools LE 7.3 &7.3.1 (003 Factory, 003 Rack, Mbox 2 Pro, Mbox 2, Mbox 2 Mini, Mbox 2 Micro, Mbox, Digi 002, Digi 002 Rack) are officially supported on Mac OS X 10.4.8 and 10.4.9 for Intel-based Macs"
This is the Waves compatibility site
https://www.waves.com/support/tech-s...ents#version-6
And there you can download Waves version 6
https://www.waves.com/downloads#older
Again, make sure your version of Mac OS matches your exact version of Pro Tools matches the compatible version of Waves plugins. That's the only way you can get it to work as it is supposed to.
If you do not follow the requirements you simply will be on your own finally.
Not to forget, Waves version 6 licenses still were housed on iLoks, on iLoks version 1. So you will have to have this ole blue dongle with the dedicated licenses on it as well, continuously connected
to your system of course, to use your version of Waves plugins.
To be honest, I have no idea if the licenses for Waves version 6 could possibly be put on an iLok 2 as well? Maybe. Anyway if you want to keep your system as it is (without any upgrading) I would recommend you to still get an iLok 1 on Ebay for a couple of bucks if you do not have one already and put your Waves 6 licenses on it finally.
Wrong.
+1
You can authorize your current Waves versions 9-10 via USB drive or machine aka computer but there's no iLok option anymore. This option ended with Waves version 8.
The best of success to you.
Cheers.
Old 11-13-2018, 04:55 AM
Something that's been missed in all this and would make things a lot more difficult is that Waves dropped RTAS in V9.91 - see this thread: http://duc.avid.com/showthread.php?t=390959
So if the op has a recent download from Waves and unless he downloaded a legacy installer he won't be able to run his Waves plugins.
Offline Bouncing Mono/Stereo plug-ins not accurate on following plug-ins Dizzi45Z Pro Tools 2018 3 07-16-2018 03:10 AM
Blue Cat's Plug'n Script 3.0 - export your creations as independent VST plug-ins unkJE AAX Plug-ins 4 10-19-2017 07:08 AM
Plug ins Missing (Kontakt, POD Farm) from Pro Tools 10 Plug-in list smythmakesmusic macOS 28 05-13-2017 04:41 AM
Super TDM Plug ins;TC VSS3,Master X,Line 6,Sonic Solutions,Eventide TDM Plug Ins Digitaliz Buy & Sell 3 07-26-2013 04:39 AM
Massey plug ins demo corupted mixer, 'Plug in Racks need reset' amerikiwi VENUE Live Sound Systems 2 09-21-2012 09:42 PM
