Old 09-07-2018, 08:35 AM
Reckless Erik Reckless Erik is offline
Default (OT) Ensemble to CP750
Today I tried to connect Apogee Ensemble to a Dolby CP750 via optical cable. All I got into the Dolby unit was left and right channels even though the Apogee software was showing all channels of a 5.1 feed. Any ideas why just stereo was going to the Apogee. Anyone tried this setup?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 09-07-2018, 10:10 AM
minister's Avatar
minister minister is offline
Default Re: (OT) Ensemble to CP750
Digital Outputs:
Optical OUT: Supports ADAT, SMUX & S/PDIF
ADAT: 16 channels 44.1-48 kHz on 2 Toslink connectors
SMUX: 8 channels 88.2-96 kHz on 2 Toslink connectors
S/PDIF: 4 channels, up to 96 kHz on 2 Toslink connectors
Looks like you need 2 Toslinks...
And the CP740 only accepts S/PDIF in on Digital 4.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 09-08-2018, 10:00 AM
Yes and just stereo uncompressed S/PDIF according to the blurb on the CP750. It will accept a compressed multichannel stream but the Ensemble does not output that on S/PDIF.
[email protected]
Newcomer Audio Post
Old 09-08-2018, 11:05 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
The CP750 will only accept AC3 stream via its optical in other wise it will play it as stereo.
You need to use either Analog db25 connector or AES db25 one in order to be able to play 5.1 or 7.1 material.
Pay attention that Dolby has not a standard Tascam / Digi pinouts but the Yamaha one.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 09-09-2018, 07:22 AM
Thank you Michael. That is most helpful.
[email protected]
Newcomer Audio Post
HTML code is On
Pro Tools to Dolby CP750 via ? nigel smith Post - Surround - Video 4 06-07-2018 01:56 AM
Apparition de saturation sur l'ensemble des pistes - ensemble inaudible [Résolue] ErwanLT Le Forum en Français 3 04-01-2018 08:35 PM
Dolby CP750 Reckless Erik Post - Surround - Video 4 09-04-2013 12:35 AM
PT 9.0.6 HD TDM with Apogee Ensemble Paul B. Pro Tools 9 1 04-01-2012 04:59 AM
Anyone using Vienna Ensemble Pro? WildHoney Pro Tools TDM Systems (Mac) 18 02-24-2010 08:48 PM
