  #41
Old 09-07-2015, 04:28 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: BUG 11.2.2: black wink when using pre-roll
Originally Posted by Frank Kruse View Post
Update:
black-wink bug still happening in 11.3.2 also in 12.x.
Same here. As well as other anomalies with 2 years old AVE.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
  #42
Old 09-07-2015, 09:57 AM
smurfyou smurfyou is offline
Its hard to tell where the priorities are. We all want bug fixes and general workflow improvements. And they have to now provide 11.x and 12.x versions, although it seems like a waste to patch 11. The main problem areas don't seem to get improvement in either case.
But there are apparently a lot of users clamoring for new features, some of which were promised and not delivered. Which Avid seems unable to provide so they unlock features for Vanilla.
Presumably they are hard at work both fixing bugs and implementing new features and these recent releases are pushed out to throw the rabble a bone. The "real" release will come later? I don't know, just brainstorming about Avid's approach here. I'd like to think something is happening but every release, be it PT or S6 or PT Control seems unfinished and half-baked.
~Will
  #43
Old 09-07-2015, 12:57 PM
mgoorevich's Avatar
I often ask my self a rhetoric question: "Maybe a new AVE just a PITA for Avid and a wrong move as there is no way it could be fixed as it is?"
If you were Avid what would you say to your customers after 2 years of attempts to fix unfixable?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
  #44
Old 09-07-2015, 01:41 PM
Ray JB Ray JB is offline
http://duc.avid.com/showthread.php?t=371663
Progress really?
  #45
Old 09-08-2015, 02:00 AM
I 'm not even talking about workflow improvements. This is about fixing things that have worked for years, then break from one release to the next and then just stay that way for months or even years (hope not in this case).
This bug was introduced when 11.2.2 came out and has been reported and reproduced frequently since then.
It was fine before and should be fixed, IMO. It breaks entire work-flows. Obviously not for everyone but for some.
Fixing it will obviously not sell a single additional S6 or other hardware and therefor might be low on their list but I think if bugs are as clearly identified, reported, reproducible and obvious on pretty much every PT rig out there it should not be put at the very end of the cue.
The bizarre roll-out of 11.3.2 for PT12 owners only isn't really clever either.
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
  #46
Old 09-08-2015, 11:58 AM
I agree completely. I'm trying to be diplomatic because I'd like to think Avid has a plan.
But these stupid longstanding bugs that broke existing behavior are getting old. They've had 4 versions and probably 10 years now to actually complete the "Field Recorder Workflow". Yet its still fussy and half-baked.
By the way, anyone using VCA's with Vanilla? Avid gave you access to them but does not want you to actually use them. If you save and later try to re-open a session with VCA's you're greeted with a prompt telling you your version of PT does not support VCA's. That I believe is proof that this feature unlocking was a rush job to placate the masses.
~Will
  #47
Old 02-03-2016, 05:08 AM
I've just re-installed a fresh system and tried BM driver 10.5.4 and was quite surprised to see that the black wink issue seems to have disappeared on my system.
Strange because AJA users reported the same issue and it showed on system without any video cards installed.
  #48
Old 02-03-2016, 05:28 AM
ex-user ex-user is offline
I only see the black wink if I've a video offset configured. Both with BM Intensity Pro and AJA Kona LHi (PT 12.4 Windows 10 - unsupported & unqualified I know ;-)
  #49
Old 02-03-2016, 05:37 AM
Ah, what a bummer. You're right. I hadn't put in my offset after the install yet.
Didn't know that was a criteria to reproduce the bug.
So it winks only when you have pre-roll, loop-playback and sync-offet on. Learned something new there.
Sorry for the false alarm.
Frank.
  #50
Old 02-03-2016, 01:46 PM
Sorry to rain on your parade. Also I see the black wink in the desktop video window as well as the hardware video output. This mis-featurette has been around a while now. It's very easy to repro.
HTML code is On
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
nudge nudge wink wink paldry macOS 2 09-09-2011 08:21 AM
Pre-roll doesn't work but post-roll does :confused: pennard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-06-2009 11:26 PM
Pre roll and Post roll keyboard commands? Bob L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2007 07:46 AM
Roll up, roll up - Get your Free RTAS Plugins... Tanglewoodstu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-24-2005 09:46 AM
