Old 02-18-2008, 11:02 PM
rockonswitch rockonswitch is offline
Default where\'s my weak link?
i'm on a quad core mac pro 2 x3 GHz Quad Core
5 Gigs RAM
Original Mbox Pro Tools LE 7.4
MAc OS X 10.4.11
My two problems are the evil "holding off USB audio increase buffersize/remove plugins" warning and excessive amounts of pops and crackles when using the mbox as the sound card. I'm assuming its the Mbox since its the only thing not up to date, and the CPU processing meters in pro tools are basically showing less than 5% of CPU usage and the RTAS is somewhere under 25% of usage. But I would also assume that these problems occur with an Mbox 2. is that correct? is there anyone who doesn't experience these problems in LE or is it inevitable? cause I've rearranged all the settings and reinstalled all to no avail. troubleshot it too. am i correct to think that my computer shouldn't be getting these buffersize warnings because of its power? or am i mistaken?
where is this going wrong?! i'm sick of these problems just getting worse
Mac Pro
Dual Quad Core, 3GHz
4GB 667 MHz DDR2 FB-DIMM Ram
MBox Original
Pro Tools 7.3.1cs5
Tiger OS X 10.4.11
Old 02-19-2008, 07:39 AM
Phil Ogden Phil Ogden is online now
Default Re: where\'s my weak link?
Have you tried updating the Mbox firmware?
http://www.myspace.com/philogg
Old 02-19-2008, 11:31 AM
yes
Mac Pro
MBox Original
Pro Tools 7.3.1cs5
Tiger OS X 10.4.11
Old 02-19-2008, 02:15 PM
DJ Insomaniac DJ Insomaniac is offline
Which USB port do you have the Mbox plugged into? Have you tried moving it to other ports to see if that changes anything?
Sam Ejnes
Mix Technician, Freelance Sound Editor/Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
rMacBook Pro 2.2 gHz Core i7, 10.10.3
16 GB RAM
MOTU 828mkII, PT 12.1 HD
Axiom 61, 2xArtist Mix
Old 02-19-2008, 05:20 PM
its been in all of them at different times. same problems. i'm wondering if i might need to upgrade to the mbox 2 pro with the firewire to handle everything. cause everything in my system is up to date but the original mbox. is there anyone who has an mbox 2 pro that still has that issue? i'll try switching the ports again just incase though. i'll post if it works, but i doubt that would be it.
Mac Pro
MBox Original
Pro Tools 7.3.1cs5
Tiger OS X 10.4.11
Old 02-19-2008, 05:33 PM
didn't make a difference thanks. anyone?
Mac Pro
MBox Original
Pro Tools 7.3.1cs5
Tiger OS X 10.4.11
Old 02-19-2008, 05:52 PM
http://i21.photobucket.com/albums/b2...Picture3-2.png
someone let me know here. am i wrong to think that if the plug in's tracks ect were an issue the system usage meters would be a lot more full than this?
Mac Pro
MBox Original
Pro Tools 7.3.1cs5
Tiger OS X 10.4.11
PT HD CORE & HD ACCEL + SSL Delta Link + SSL Alpha Link Noizz focushocuspocus Pro Tools TDM Systems (Mac) 1 09-29-2012 08:12 PM
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? azirkin macOS 1 01-17-2012 01:30 AM
What's the weak link of the 002? Pres, converters? bassface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2004 12:20 AM
More CPU,RAM,should be faster.Wheres my weak link. east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 12-24-2003 09:00 AM
Digital Audio Extraction Link. Is this a good link? GuitarEasley General Discussion 0 04-16-2002 09:26 PM
