Old 12-18-2019, 07:16 PM
firmflange's Avatar
firmflange firmflange is offline
Default Kontakt Player only Records when its own track is selected..Help!
Can someone help me, here's my situation:
Peripherals:
Rec from: MPK261 (keyboard), Send to: Kontakt 5 MIDI in1
I make a stereo Instrument track
I assign Kontakt player to the insert
Output is the same as all other tracks
The signal comes fine through the keyboard and records...but...
Now even if I just select a different track, the Intstrument track stops recording and the disarms the record function. Can someone help me figure out how i can keep this recording and still select different tracks?
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Old 12-18-2019, 08:07 PM
Default Re: Kontakt Player only Records when its own track is selected..Help!
2 thing that may help here:
#1-don't select tracks while recording
#2-if you want to record more than 1 instrument/midi track at the same time, You have to record-enable them at the same time(with a single command). IIRC, it might be the Option key(option-click the record button on an Instrument track and that will record-enable all Instrument tracks). OR, it might be highlight the tracks you want and then hold Shift+Option+click on the record button(this is the idea anyway, but I'm a Windows user so I ight be thinking the wrong modifier key)
Old 12-18-2019, 09:42 PM
firmflange's Avatar
Thanks Dave, I applied some of your advice here. This is what I came up with:
(At this time I only wanted to record 1 Instrument track)
I inserted the Kontakt player on the Instrument track like before, but like you said, I didn't arm it for record.
I sent the output of the Instrument Track to a buss (1,2).
Then I made an Audio Track and set the Input to accept the 'buss 1,2' (signal from the Instrument Track), and armed the Audio Track to record.
The drawback to this of course is the Instrument Track gets reproduced as a destructable wav, but I'm not really concerned about editing the MIDI data anyhow...I just want the piano tones.
Also, while its being recorded, the Instrument Track data (in this case, piano), does not get written to the track, but does create the same audio information onto the wav (audio) track as the piano keyboard is being played in real time.
Still don't know why the initial situation exists, but this way seems to be effective for me. Thanks again Dave.
Old 12-18-2019, 10:43 PM
Southsidemusic's Avatar
And please dont start 3 threads for the same issue next time. Thanx
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-19-2019, 09:14 AM
firmflange's Avatar
My Bad, Chris. Thanks for the help.
Old 12-22-2019, 12:42 PM
DonaldM's Avatar
DonaldM DonaldM is offline
It might be easier for you to just record the part directly on the instrument track, or on a midi track pointed to the instrument track. When you have the way you want it, then just use commit to create the audio track. That way you can edit the MIDI to get the audio exactly how you want it.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 12-22-2019, 12:50 PM
firmflange's Avatar
Yes you are right Donald. I forgot all about committing.
Old 12-22-2019, 07:32 PM
DonaldM's Avatar
It makes life much easier.
Old 12-22-2019, 08:32 PM
No worries brother. Just so all the answers are easier to find, thats why we have that forum guideline and it is harder if there are more threads for anyone to follow when members answers in different thresds so best keep it in one place per topic for ”ease or use
Thanks and Happy Holidays
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Kontakt Player 5.6.6 outputs Shinz Virtual Instruments 1 03-15-2018 04:51 AM
Kontakt 5 Player will not appear! ka4bi Pro Tools | Intro Discussion 4 06-10-2017 12:35 AM
FREE NI Kontakt Player audiogeekzine Virtual Instruments 20 08-13-2009 06:54 AM
Kontakt player not working. Assi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-27-2009 11:19 PM
