  #21
Old 06-27-2013, 12:12 PM
Syrcular Syrcular is offline
Default Re: Codec error on video import
Wish that was posted somewhere in the Pro Tools documentation. I learned the hard way...but luckily it's out today, so all is good.
  #22
Old 06-27-2013, 01:02 PM
Arrow Re: Codec error on video import
For the record - Pro Tools 11 Co-Install Information
Glad to hear you have things sorted out.
  #23
Old 06-27-2013, 01:24 PM
tom_lowe tom_lowe is offline
Any idea why this may be happening without any version of MC installed? Some videos will load and scrub but not play, most including ProRes QuickTimes and DNxHD MXFs won't even import. System has 16GB of RAM.
  #24
Old 06-27-2013, 02:08 PM
Question Re: Codec error on video import
Do the ProRes QuickTimes play in either QuickTime Player (v7) or QuickTime X?
  #25
Old 06-27-2013, 03:01 PM
Yes, and Premiere Pro and Pro Tools 10.3.6
  #26
Old 06-28-2013, 10:09 AM
willco willco is offline
Yep could do with a fix to this if I am to try and put pt11 through it's paces - just seen the co-install specs for the first time which explains why my setup doesn't import quicktimes of any codec I have tried.
Why is this a problem? Is this being reviewed or fixed by Avid??
  #27
Old 06-28-2013, 01:00 PM
Why is what a problem? v10.3.6 does not use the Avid video engine and is a 32-bit application. v11 uses the Avid video engine and is a 64-bit application. What would you want Avid to fix here?
  #28
Old 06-28-2013, 05:58 PM
Make it work properly?
  #29
Old 06-29-2013, 02:23 AM
Is there a order in which I should be installing MC 7 and PT 11? When I uninstalled everything, and reinstalled just Pro Tools, all was working well, however, when I installed MC7, it seems to have broken PT 11 again, going back to the same issue when I had MC6.5. I just tried manually uninstalling PT 11, and reinstalling but the missing codec error has returned!!
Any advisement? I mainly use PT 11 for video so it's very important for me.
Thanks,
Peter
  #30
Old 06-29-2013, 06:53 AM
conleec conleec is offline
Yeah, same problem here. Two machines: a 2009 Mac Pro and a 2013 Macbook Pro with retina display and 16Gb of ram. Both machines have Media Composer 7 installed.
Mac Pro has working video import in PT11. Macbook Pro refuses to import video, throwing an error about missing codec, or something to that effect.
Very frustrating indeed.
Chris
Error message when trying to import a video to a session cedlil Pro Tools 11 0 03-03-2014 09:11 AM
Solving a Codec Error when importing video Dizz Tips & Tricks 0 10-04-2013 05:14 PM
Import Video error -2015 matt connolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-28-2009 03:57 PM
IMPORT VIDEO ERROR Audio FILE alx002 Pro Tools TDM Systems (Mac) 1 10-01-2008 12:31 PM
Video import Error SteveH44 Post - Surround - Video 0 09-10-2008 12:00 PM
