Problem Converting Instrument Track to Audio Track
Hello,
I am new to pro tools and am running the following system: Pro Tools 7.4.2 Digi 003 Factory iMac 3.06 Ghz Core Duo 4 Gigs of Ram Leopard BFD2 Plug-in This is my problem: I have programmed BFD2 midi data to a stereo instrument track and I want to convert it to an audio track. I have routed the output of the instrument track to bus 1-2 stereo and have created a new stereo audio track where I have the input routed to bus 1-2 stereo. The problem is that i get no signal on the audio track... I can, however, get signal from the instrument track to an auxiliary track or another instrument track - just can't get signal on an audio track. Am I missing something? Any help would be greatly appreciated. |
Re: Problem Converting Instrument Track to Audio Track
Sounds like it's a monitoring issue. You should get level once the audio track is record enabled otherwise Toggle Auto/Input Only monitoring.
http://www.myspace.com/philogg |
Also make sure that the Audio track has a valid output assigned (it should default to you main monitor outputs, but check to be sure).
Gentlemen,
The problem was indeed a monitoring issue. I thank you very much for your assistance - this is a great resource for guys like me whoi are coming up the learning curve. Thanks again. |
Hi I have the same problem i have posted Midi form a synth(vi one and am trying to convert to audio but no signal.I think it is a monitoring issue but am not sure how to fix it
also what do you mean by toggle auto input only. |
Recording instrument track to audio track | Durstlaw | Tips & Tricks | 9 | 04-02-2014 04:37 PM |
Instrument track picking up my microphone, but not my audio track. | raddster | Pro Tools 9 | 5 | 01-20-2012 04:11 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
bouncing from instrument track to audio track | rolew | Pro Tools M-Powered (Mac) | 5 | 04-18-2009 02:01 AM |
GOING LOONY From instrument track to audio track | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-18-2007 04:47 PM |
