Closed Thread
Old 02-08-2013, 08:14 AM
Filmusic Filmusic is offline
Default bought heat how to install [solved]
i'm running 8.1.1HD
just purchased an ilok asset for heat
do i need an installer , or do I reinstall PT and select the/a heat option at install (provided there is one there,,, at an PT HD 8.1.1 install sceen)
Old 02-08-2013, 08:31 AM
TOM@METRO's Avatar
Default Re: bought heat how to install
The installer should be on your disk.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-08-2013, 08:44 AM
hi
I bought my PThd 8hd license without an install disk (bargainbay)lwill the heat trial work to authorize - as the heat asset is on my ilok
Old 02-08-2013, 08:53 AM
TOM@METRO's Avatar
It should.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 02-08-2013, 09:00 AM
thanks - fingers crossed
Old 02-08-2013, 03:23 PM
well...when i was registering my trial it gave me a HEAT set-up file - thought I won - installed heat - then opened PTHD 8.1.1 - could not see it in the mix window - I then quit PT went to ilok to accept the trial asset - the trial asset would not download - stating that I had a full license for heat on my ilok (ha ha - ouch)
so...heat is somewhere within my PT - i'm just not certain of where to find it - thoughts? (it shows up as an installed program on my computer in my control pannel - I have enabled it within my Pref/Processing and have it active under Options - just can't see it in my session - scratching head)
Old 02-08-2013, 03:33 PM
TOM@METRO's Avatar
Lower right hand corner of the mix window. Tiny box.
And in the view dropdown> Mix window view> HEAT
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 02-09-2013, 07:43 AM
Tom - thanks - got it - diving in!
Closed Thread
Mbox 2 Pro crashed Pro tools 11.1.2 - Solved problem bought new Mbox 3 ;) shamanrock Pro Tools 11 0 02-15-2014 03:36 PM
I bought Pro Tools 10 not showing up in iLok [solved] CalebKing21 Getting Started 15 10-16-2013 05:25 AM
install loop and install failures Solved.....so far soybalm Windows 1 04-17-2012 08:40 PM
Possible prefs question relating to Heat install bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 02:50 PM
Just bought HD2 Anyone Got Any Install Tips? wolfman_rob Pro Tools TDM Systems (Mac) 1 10-30-2006 10:37 PM
