Uninstall Heat
How do you uninstall Heat? I've already deleted Heat from my Plugin Folder and it still pops up as I open PT. Thanks.
Re: Uninstall Heat
Just a guess though ...
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Re: Uninstall Heat
Not that it's really relevant to your question but, just out of curiosity, why are you uninstalling HEAT?
Re: Uninstall Heat
HEAT can be bypassed even if it's installed. However if you want to uninstall HEAT just move the plugin to unused folder
Re: Uninstall Heat
He's already deleted it from his plugin folder.
Re: Uninstall Heat
It's not activated and I'm not going to buy it. It pops up to activate every time I start PT. Where are the aax plugins?
Re: Uninstall Heat
system HD/Library/Application Support/Avid/Audio/Plug-Ins
Re: Uninstall Heat
Thanks!
Re: Uninstall Heat
I thought you said in your original post that you had already deleted it from your plugins folder. How could you do that if you didn't know, until STeff's post, where the plugins folder was?
On a side note, I would highly recommend demoing HEAT. It can do some really quite amazing things to a mix and can be purchased at a much more reasonable rate on eBay if you look around. |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
How do I uninstall PT10? No 'Uninstall' option in Control Panel | epu | Windows | 5 | 06-26-2012 06:25 AM |
HEAT and PT 9 non-HD | chicken | Pro Tools 9 | 1 | 11-10-2010 06:43 AM |
Heat | Fullsound Recording | Pro Tools TDM Systems (Win) | 2 | 09-06-2010 10:31 AM |
Can too much heat do this? | Bodhisan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-18-2004 09:20 AM |
