Old 07-17-2017, 03:31 PM
LightWing's Avatar
LightWing LightWing is offline
Default Re: Do you really have to completely restart Pro Tools when connecting a MIDI control
I've run into this quite a bit actually. Its as if PT doesn't see the ports activated when a device is turned on after its been launched. I've also had occasions where a full reboot has been the only solution. I categorize it as a "Go Figya" So my solution has been to have ALL external devices powered up BEFORE I boot and the issue never comes up. :)
Patrick
www.LightWingStudios.com
Musical Instrument Protection Accessories...Made In America.
Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife!
AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield
Old 07-18-2017, 06:41 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Not the same as your problem but on my Windows 10 machine I have several midi devices connected either through a USB hub or directly to the computer itself. I have an LPK25, an MPC Ren (I don't use anymore), Maschine Studio, NI S49, Antelope Trinity, Akai Advance 61, Grace Design M905 and the M-Audio 2x2 Anniversary Edition Midi box. Besides the Trinity not connecting during boot up every know and then, the M-Audio 2x2 will do something weird where it will show up in the Device Manager but it will not allow any Midi device connected to it to show up as a usable device be it Pro Tools, Studio One 3, Reaper or FL Studio. For some reason if I connect the M-Audio directly to the computer and not via a sub hub it won't work no matter what I do. When it's connected via the usb hub it normally operates correctly but every so often I have to run the M-Audio installer, select uninstall and run it, after the uninstall process has completed re-boot my cpu and after re-boot run the installer to reinstall the drivers and I'm all set again. I use the M-Audio for the plugin that allows me to control my 2 Bricasti M7's in Pro Tools, Studio One 3 and Reaper via midi. The times I have to do this I do not have to re-boot my computer for Pro Tools to see my M-Audio 2x2 midi device. This just has to be done before I launch PT and everything is good. What I did find out was that some midi devices will only work through my usb hub which is puzzling to me. The Trinity is hit or miss through the same hub as the M-Audio (with or without the M-Audio Connected) but about 98% or the time it just works when connected directly to the computer's usb port and when the Trinity doesn't connect correctly I usually just turn it off and on again then I'm all set.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 07-19-2017, 03:57 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Wow! Sounds like you need to have a ProTools start-up checklist longer than the astronauts have to launch into space.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 07-31-2017, 07:09 PM
abc1mce2's Avatar
I know it sounds like a lot, but usually when I boot up everything works fine....but if something is wrong at least I know where to start as well as a solution.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 08-10-2017, 02:48 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Imho this is just one of the crappy windows bus architecture/driver issues
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
  #16
Old 11-06-2017, 09:10 AM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
In September 2016, Windows 10 added the ability to detect MIDI device arrival/removal:
MIDI Enhancements in Windows 10
https://blogs.windows.com/buildingap...zXwyeWwTp7Q.97
It looks like Cakewalk is already taking advantage of this. I hope Avid will take advantage of this as well. Having to restart your DAW to plug in a keyboard is a bit silly. I know some people just have them permanently plugged in, but not everyone has a setup where this is feasible.
  #17
Old 11-08-2017, 08:26 AM
YYR123's Avatar
YYR123 YYR123 is offline
Super cool, did not know about that......
Daniel
  #18
Old 08-12-2019, 05:05 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I'm bumping this as this has not been implemented in Pro Tools yet. Don't know why???
It would be great to have this work on Windows.
Connecting MIDI controller properly to PT 11 AanoNin Pro Tools 11 66 06-12-2014 02:33 PM
Connecting MIDI controller... TheHunter1787 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2010 01:38 AM
connecting MIDI keyboard controller in PT PatrickJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-18-2004 01:38 PM
Need help connecting midi controller, keyboard, and rack. ixnys MIDI 1 03-04-2002 02:48 AM
Need help connecting keyboard,rack, and midi controller ixnys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2002 03:23 PM
