Re: DAE Error 743 Encountered
I tried changing it to "1 Processor" instead of 2. It fixed the constant lagging and jittering of the mouse curser, but if i tried to even play what i was working on, it would say i need to up my CPU usage for PT. I'm confused!
This is just a thought based on a few experiences I've had with DAE errors. It seems like they're usually related to the info flowing properly from your HD so where/how you have it connected is important. I've fixed DAE problems before by checking all my cables and making sure they're plugged in securely. Little things like that can make a difference it seems.
using PT 2023.9, 24' iMac M1 16GB RAM, Ventura 13.6.1, Apollo Twin interface |
I just started getting this error out of the blue on my new MacPro. This machine is a monster. 12gb of ram, 24 core, 4x 1TB internal drives....
And yet protools 8.0.4LE refuses to work on it for more than a day or so. Todays issue was it not recognizing the mBox. When it finally did (for no apparent reason) I got Error 743. I tried moving the project around to different drives (internal external) and changing the amount of processors, cache, etc... nothing works. I tried moving the usb port and restarting and PT stopped recognizing the box again. This issue has been reported now since at least July and there is no official word about a fix. Just anecdotal voodoo fixes from desperate users. I don't want to have to learn a new editing software but this is totally unacceptable. I don't know how AVID gets away with it. |
any ideas out there. As noted, it would lovely if the errors built in to the software actually correlated with some kind of support available... ho... and hum...
Mac Computers/PT12/Lots Of Lacie D2s |
I have a new MacBook Pro and did a test at home and recorded something with the MBOX 2 I am using on the road. I intended to mix while on a 2 month trip now away from home, and I get DAE Error 743 on old projects recorded with my DIGI002 and even on the new things recorded a few days ago.
I am in Thailand now with this and it doesn't work, wasting my time and money... Incredibly frustrating. A long intensive mix of an album has turned into a no work situation. I have tried switching USB ports, no help, and restarting... I have NOT updated Pro Tools since installing in this machine either. Please, some Tech on Avid help us.... |
#16
I bought a brand new USB cable - no help - and installed the cs2 update, which did not remedy the situation. No help available, it seems!
a very disgruntled customer who has run Pro Tools since the Audiomedia card days. Bert |
#17
I ran into this issue yesterday with a friend of mine, and I found a solution that worked.
First we ran JCDeshaies Pref/Database deleter program. http://www.jcdeshaies.com/ Make sure to check the box to delete the "Digisetup" file too. (This is unchecked when you 1st open the program). After trashing the preferences, emptying the trash, and then restarting we did a PRAM reset. To do the reset you restart your computer, and when the screen is dark (before the apple icon appears) hold down the Apple Key, The Option Key, and the "P", and "R" keys at the same. The computer will "bong" at you as you do this. Let it cycle three or four times then let go. Let the machine reboot, and relaunch Pro Tools. This solution worked for us... Hope it works for you guys too. Kelley Creative Director Krash Creative Solutions |
#18
Kelley
MANY thanks for the informative tip. I did it 3 times, just to make sure, but after each time I still got the same DAE Error 743 Encountered message. Frustrating. I didn't know about the Prefs deleter you linked to so that was a good one for the future. Hopefully some other users may benefit from your tip! Cheers Bert |
#19
I was just wondering if any of us with this problem has deleted 8.0.4 and reinstalled 8.0.1 and gotten it to work ?
#20
downloading 8.0.3 and going to test a reinstall
will post what happens cheers Bert |
HELP DAE-error __ was encountered | helmer | Windows | 2 | 10-23-2013 02:56 PM |
DAE error -4 was encountered | Nils Groth | Pro Tools TDM Systems (Mac) | 4 | 03-17-2009 05:20 PM |
DAE error 2 was encountered?!? | Mike Czech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-03-2002 10:25 AM |
DAE error -199 encountered | ripe | Pro Tools TDM Systems (Mac) | 1 | 01-25-2002 06:39 PM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
