Old 11-03-2017, 02:16 PM
Robusto Robusto is offline
Default Cannot change clock source
Pro Tools 8.0.5
Digi 002 Rack
Win 7
I am trying to hook up a Boss DR-880 via SP/DIF. I get a signal, but it's full of those familiar crackling sounds and there is too much latency delay.
When I go into Setup > Hardware and attempt to change the Clock Source to SP/DIF it just pops back to Internal. Anyone know why it's not letting me change it?
Old 11-05-2017, 01:29 PM
Default Re: Cannot change clock source
Is Windows using the 002 as its default playback device? If so, change that so Windows uses the on-board sound card.
Old 11-05-2017, 06:35 PM
Here's what that looks like right now:
Old 11-05-2017, 08:31 PM
Okay, What kind of digital output is on the Boss, lightpipe or RCA? If its RCA, change the Optical Format(in Setup>Hardware) to ADAT, which should(might) allow the RCA SPDIF to work(shooting in the dark since I don't know how things are connected). Assuming the 002 is fully working(not a sure thing due to the old "power harness" issue), the biggest reason I know for clock source defaulting back to Internal is because the connection sees no clock. Reasons for this:
1-Roland is not outputting signal on its digital output(is there a setting in the Roland that needs to change?)
2-the cable is bad or not seated(the plastic optical connectors are pretty crappy)
3-the signal from the Roland is at a different sample rate than the session.
Hope something here helps. I clocked my 002 via ADAT(lightpipe) for years with several 8-channel outboard preamps(Presonus D8, Firestudio and Focusrite ISA-428 with digital option card)
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Cannot change clock source Clockwork12782 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-17-2017 01:06 PM
Problem detected with audio clock. Check your clock source and sample rate. teleguy2 Windows 6 06-26-2015 01:47 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
