Sound replacer
hey im running sound replacer on pt9, fairly new to using it
the issue im having is when i load a sample to trigger the sample will preview within plugin, but once i hit process it doesnt actually replace the sound in my session probably something very simple im missing but still missing it! any help would be greatly appriciated |
Re: Sound replacer
Is the little "Use in Playlist" button lit? It needs to be, otherwise its creating the new audio and just sending it to the regions(clips) bin and not to the actual track.
Re: Sound replacer
Are you pulling down the trigger threshold for the sample?
I've found that if you pull the left one all the way down, then the middle one to where it recognizes only the transients you want to replace, then put the sample on the far right one and pull it down to the middle one, that's when it works best.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
Sound Replacer | mastermorris | Tips & Tricks | 2 | 01-28-2007 06:33 PM |
Is there a drum replacer/sound replacer??? | sethbrand | General Discussion | 2 | 03-08-2006 08:40 AM |
my sound replacer makes the samples sound higher | joeldavidlauver | Pro Tools TDM Systems (Mac) | 2 | 05-24-2005 07:59 AM |
Sound Replacer Alters Sound of Sample. | vze24x2x | Pro Tools TDM Systems (Mac) | 0 | 10-25-2003 07:10 PM |
Need help with Sound Replacer | Matty Spindel | General Discussion | 2 | 03-13-2002 11:55 PM |
